Bone Stock Dyno Run?
Old Oct 17, 2005 | 07:08 AM
rbrown81's Avatar
But why is teh Rum gone?
Does anyone have a dyno slip of a Bone stock 03 6spd doing a Dyno run. I didnt get a chance to hit the dyno before I installed my headers, so Id like a ballpark figure for comparison.
If you have a slip with a dyno run with a stocker with Berk intake, that will give me an even better basis for comparison.
Now hopefully I can resist the temptation to install my UDP before my dyno time on the 27th..... ugh!
Cmon 240whp!!!
Old Oct 17, 2005 | 07:19 AM
maxmale's Avatar
did you come stock with the hlsd? my thoughts are you should be around 210 stock whp
Old Oct 17, 2005 | 07:48 AM
Puppetmaster's Avatar
200 to 208 whp is typical....
DYNO forum is your friend: http://forums.maxima.org/showthread.php?t=282615
Old Oct 17, 2005 | 07:51 AM
What is the connection between HLSD and whp?
Old Oct 17, 2005 | 08:26 AM
rbrown81's Avatar
I do have one though.
Old Oct 17, 2005 | 08:39 AM
01GreyLustreSE's Avatar
hmmmm i wonder if i have one... im 01 i just did a burnout like 5 min ago and both tires where spinning.. both tires left marks
Old Oct 17, 2005 | 09:17 AM
http://forums.maxima.org/showthread....highlight=VLSD
Old Oct 17, 2005 | 09:48 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by NmexMAX
212-220 wh/tq typically
I was just finishing your statement Puppet ....(TQ)
Old Oct 17, 2005 | 10:00 AM
I still think that's a little high since I'm pretty sure the stock 03 #s were overrated just like the 02s.... got dyno?
MaximaDave's stock 2k2 got 204/219...
Old Oct 17, 2005 | 10:14 AM
NYPD-Arnold's Avatar
Z
This is correct. HP numbers will be around 200, TQ numbers will be around 220.
5.5 gens are powered by the same engine that the Murano uses: 245HP/246TQ
Old Oct 17, 2005 | 10:23 AM
NmexMAX's Avatar
dot dot dot ...
Read post again ... Torque ... .. I wasn't referring to HP ...
Old Oct 17, 2005 | 10:26 AM
I thought you meant 212/220 whp/tq for some reason. Lean how to expressive you thoughts bettAr.
Old Oct 17, 2005 | 10:27 AM
Thanks...
Old Oct 17, 2005 | 10:29 AM
NmexMAX's Avatar
dot dot dot ...
READ bettAr whtq .. is that better
Old Oct 17, 2005 | 10:45 AM
I knew I set myself up for that... so the final answer is:
Stock 02-03
WHP: 200-208
WHTQ: 212-220
Old Oct 17, 2005 | 11:44 AM
steven88's Avatar
Need A Light?
I don't think its that hard to hit 240whp? Rbrown what do u have? I/H/E right?
yeah 240whp should be easy for u...there are a few guys who dynoed with 233-235whp with a stock cat and stock catback....so i'm thinkin, with u having an exhaust over them, you should get 240whp
Old Oct 17, 2005 | 03:07 PM
NmexMAX's Avatar
dot dot dot ...
Area under the curve = FTW.
Peak #'s are
My #'s are nearly 1hp apart from other dynosPEAK .. but under the curve I lack a good 12-15 ftlbs ... So tuning is your and my friend.
Old Oct 17, 2005 | 05:20 PM
6spd_Hayes's Avatar
I will have a bone stock 2k2 6 speed with HLSD dyno done very soon. I put my car back to absolute stock so I could get a good baseline before adding the Cattman Gen II headers.
I went as far as putting back in the original air filter that came in it from the factory.
Old Oct 17, 2005 | 05:22 PM
venom32225's Avatar
Let us know the results!!!
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
Justin Kroll
Sep 2, 2015 11:06 AM
