Permanent Rear wheel alignment damage?
I rode the back left wheel over a HUGE crub at high speed while making a turn by accident about 3-4 months ago. Now I've tryed to have it realigned and everyone i have talked to say the rear wheel does not have adjustable alignment, i even looked in the nissan serivice/repair manual and that confirms it. Now i need to rotate and buy new tires regularly, any possible suggestions on how to get it fixed?? this happened about 4 months ago now.
95max gle 160k
thanks alot!
95max gle 160k
thanks alot!
You cant align the rear on our cars. Someone correct me if I am wrong, but the fact that your rear alignment is off means that somehting is bent. Replacing what is bent is the only way to "re-align" your rear wheel.
im no expert on alighments. but you should really post your alighment specs. if it is way out of wack, call it a day and try to find a rear beam in a junkyard. if it is slightly off, its possible to have it shimmed.
i had alighment issues since i bought this car almost 2 years ago. ive seriously had about 6 or 7 done, by various shops/ machines/ techs. ive found the biggest difference in the person using the machine. if you are not far from the nyc area, i can recomend you to guy that was the only person willing to spend a little time to get my car as perfect as it could be.
If the rear axel beam is bent your rear alignment will be off.
You have two choices:
1) Get another rear beam
2) Sell the car.
You really should get a 4 wheel alignment so you can actually see how it's tracking. Then you can make a decision as to what to do.
2) Sell the car.
Huttig2009
Sep 25, 2015 03:31 PM
