too many hids. 02/03guys hid brights?
il be finally upgrading to the 02/03hids within the next few months, i have 8000K BIXENON heads and 8000k hid fogs now, just not too happy with them.
i plan on replacing the d2rs with 6000ks and replacing my fogs with 6000ks to match.
has anyone put hids in the brights? of the 02/03s theyre 9005s as far as i know of. i know it would be overkill, but ill have two sets of hids left over, gotta do soemthign with them.
don't put HIDs in your hi-beams, you'll kill them in no time flat. plus that slight charge up time on HIDs will render them useless for hi-beams. stick with the stock and upgrade the low-beam to 6000k. that's what i have and i love it.
sounds good to me, i just wanted to see how bright i could be without retrofitting, i guess when the tiem comes i just sell my hid kits and start over, im not too happy with my fog kit, the right one takes a couple fo trys to turn on soemtimes..
maybe ill end up using them as reverse lights
Doing what you plan will improve light output, without losing too much color.
If you decide to put HIDs in your brights, as others have mentioned, your flash to pass feature is pretty useless, unless you have a way to power your HID all the time as low voltage (never been done to my knowledge).
Anyways, hope that helps.
i live in the middle of nowhere, so i like ot be as bright as possible, lots of wildlife. i usually have my highs on for a few minutes, not just top flash, i never flash. i think id need to run the power off the batt, cause it would overload the harness. or just wire them up on a seperate switch.
You would need a hi/lo kit for your car. We can offer you that as well.
why would i need a high/low kit.if i use 02 housing and get the harness i need, the d2r is the low the 9005 the high. i have a highlow kit already, but would rather sell it and use my non highlow kit as my highs
otherwise ill make my own, converting a 9004 to a d2r and 9005 isnt that hard to do, ive done custom harnesses b4.
the color looks good...the light output doesnt...stock is 4300k...6000k looks the whitest without loosing 2 much output...now question...has ne1 changed the 4300k bulbs to 5000k?? any noticeable difference?? i heard after a while they go to looking like 4300 either way...jus wondering...
Originally Posted by umnitza
No, the color doesn't look good either. It's a ridiculous purple/pink and it's bad glar.
4300= yellow
5000K = more white
6000K = more bluish.
4300= yellow
5000K = more white
Originally Posted by Italiano
i know i just ordered a replacment ring for my ddes from you guys. but do you think you can email me the price to replace the stock bulbs in the 2k2's for 6ks to match my fogs..? im interesting in doin this upgrade, depending on when i have some extra cash.
3000= yellow
4100k-4300k= OEM
5000K = more white
3000= yellow
4100k-4300k= OEM
5000K = more white
Originally Posted by custommaximaSE
Hey umnitza,
I want to order HID foglight kit .How to order it ?.I can't find it on your web (not sure wich one to get).And the price do i get discount?
Hey Matt,
Just wondering why you dont recoment wining directly to that battery.
I put an HID kit on my old SAAB using the harnesses and totally screwed my headlamps within 6 months. When installing HIDs on my Infiniti I wired to the batt. It's been over two years and they are still running strong.
Its not worth it. In the amount of time you actually use the brights, the HIDs wouldnt have enough time to warm up. I did this years ago, and ended up taking the kit off because of disuse
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
