CEL flashing; i don't know why
Old Dec 10, 2005 | 12:46 PM
slicey's Avatar
the CEL is flashing while i'm driving. i don't mean it's in diagnose mode. i replaced CTS, then cleared CEL codes. afterward, this is when i started getting the weird behavior. any ideas, gentlemen?
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread.php?t=104931
Old Dec 10, 2005 | 01:09 PM
njmaxseltd's Avatar
You have a misfire.
Old Dec 10, 2005 | 01:22 PM
MDeezy's Avatar
multiple mis-fires
Old Dec 10, 2005 | 09:39 PM
themills's Avatar
I only had one, and it was flashing.
Old Dec 10, 2005 | 10:17 PM
f550maranello2's Avatar
you might have left it in self diagnosis mode... happened to me a couple of times lol
Old Dec 11, 2005 | 03:21 AM
slicey's Avatar
the CEL flashes about 20 times, then stops for about 10-15 sec, then flashes again. does a misfire have a code? because my engine is running CRAPPY. engine very shaky/rough running. have to drive w/ tach higher than 3000RPM to make most of roughness appear to go away, until RPMs go under 3000 again. arghhh. if bad fuel injector, is code for that problem? i did replace all on rt. bank over 3yrs ago so maybe lt bank having a bad injector or two?
Old Dec 11, 2005 | 01:17 PM
themills's Avatar
Go to autzone, and when the light blinks, press read. Stop guessing because you won't be happy if you guess 500 dollars worth of unessecary repairs. If you have a bad injector, I believe it can throw a misfire code, and a bad misfire is USUALLY the culprit for a blinking SES.
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 10, 2015 09:35 PM
Colossus
Sep 9, 2015 05:46 AM
intimidator
Sep 5, 2015 07:23 PM
A32goldylocks
Sep 2, 2015 06:39 AM
