Automatic Transmission Flush (2002 3.5)... Do I have enough fluid in there?
I flushed my 2k2 3.5L automatic transmission today using method in the How-Tos (drained 4qts from the pan, then drained 2qts at a time from the hose that was plugged into the radiator)
According to the owners manual, I can check the fluid in the cold range when I get the car to operating temperature, shift it through all the gears, and then check while idling. When I do this, I only see a hint of fluid on the edges of the stick.
When I let the car cool down and check the fluid when the car is off, the fluid is within the cold range.
Because no fluid is appearing when the engine is at temperature and idling, I'm pretty sure I need to add more fluid because it's not really showing up on the dip stick.... am I right?
Yep, keep on adding and checking your fluid. Same thing happened to me when I did mine and I actually had to go back to the store to buy another liter of fluid. Just make sure you take your time and add slowly, drive a bit, add some more and repeat this step until your up to the full line. Good luck.
torque converter?
i heard from some of my buddies over in the tech shop at mercedes benz that the only way synthetic ATF will do any good is if you also drain the torque converter and replace that with synthetic ATF as well... is it possible to drain it? is this true?
sorry im not familiar with the forums *cough cough* <-- newb lol what do you mean follow mi Sig?
http://www.cardomain.com/ride/335521/3
or click on AT Tranny Flush on his first post.
sctludwig
Sep 1, 2022 01:32 PM
Justin Kroll
Sep 2, 2015 11:06 AM
