Sponsored by:
Sponsored by: CARiD
DEK Swap Complete - Rpms keep bouncing between 1600 & 2400
Old Dec 21, 2005 | 07:14 PM
Max4Speed's Avatar
www.autotalk.com
Looks like everything went smooth and no CEL. But the only problem is that my idle is messed up and the screw on the IACV doesnt do much. I can screw it in all the way or out.. same sound. Car is idling @ 1600 when I start it but as it gets warmer rpms will bounce between 1600 and 2500.
Any thoughts?
Old Dec 21, 2005 | 07:21 PM
Kevlo911's Avatar
Kevlo for President
How is the MAF, can you hear any air leaks?
Old Dec 21, 2005 | 07:27 PM
Max4Speed's Avatar
www.autotalk.com
MAF was good before the swap.........
I think I need someone else to hear it. I am deaf now lol
Old Dec 21, 2005 | 07:58 PM
Kevlo911's Avatar
Kevlo for President
Haha, you prob got used to that sound by now. Get Jay or someone to check it out. I bet its that extra 50ft of wire
Old Dec 22, 2005 | 05:08 AM
Curt's Avatar
Something I suggest to the guys who’ve bought the 00VI setups from me and I’ll pass on to anyone who is planning on doing this:
Before you start disconnecting wires and hoses, have a bunch of small tags with string/rubber bands/etc. to attach them to each and every wire and hose you remove. Label them sequentially (e.g., A, B, C, etc.), and then on a pad of paper list them along with what they were hooked up to. This ought to be a pretty foolproof checklist to make sure that you haven’t overlooked something as you hook things back up again. Although it may sound sort of “beneath” the mechanic-expertise of some of you guys, I think it’s reasonable to say that most of these sorts of problems guys have encountered in the wake of the 00VI installation have been the result of something that was overlooked. And sometimes a beer or two while we’re working has a way of clouding our memory about what went where. Although most of you aren’t going to be flying your cars at 30,000+ feet, there’s a reason why professional aircraft mechanics have detailed, step-by-step checklists for the procedures they perform.
Another one I’ll add to that list is the fuel pump fuse: if you pull that fuse and fire up the engine before you do anything else, that’ll bleed off most of the fuel pressure before you start opening up the fuel lines and avoid having fuel spray in your face. I forgot to reinstall that fuse, and had a hell of a time figuring out why my engine wouldn’t fire up when I was done with the installation. I’d wager that even the most experienced among us has had similar “doofuss” experiences (that many of you won’t admit to).
Merry Christmas, everyone.
Old Dec 22, 2005 | 06:13 AM
Stephen Max's Avatar
Try lowering the idle with the butterfly plate adjustment screw on the the throttle body. Just back the screw out a little bit and restart, do it again until you get it right.
Old Dec 22, 2005 | 10:54 AM
jmeister's Avatar
Check the TPS if you removed/moved that at all.
Old Dec 28, 2005 | 08:03 AM
JeEvE's Avatar
How did you setup your IACV? Hose thickness should be fine since it would idle lower if it was not.
Old Dec 28, 2005 | 08:06 AM
Max4Speed's Avatar
www.autotalk.com
IACV is mouted using the custom bracket from StephanMax. I am using a 5th gen throttle body and TPS so may be I need to check that?
What are the symptoms of TPS going bad compared to IACV going bad?
Old Dec 28, 2005 | 01:28 PM
nismology's Avatar
I doubt the TPS is bad. It might be out of adjustment however.
Old Dec 29, 2005 | 11:22 AM
kraimer21's Avatar
99% is the chance that you need to re-adjust the tps. we had the same problem on my buddy's 5th gen. we took apart a tb to clean it and after putting it back together, we didnt adjust the tps. the rpms were bouncing at around 1800. however before taking everything apart we marked the original position of the tps with respect to the tb. we put the tps to the original position and everything was back to normal. try resetting the tps (500 ohm at idle and 4000 ohm at wot)
Old Dec 29, 2005 | 11:40 AM
Max4Speed's Avatar
www.autotalk.com
Is there a certain procedure I have to follow to reset it?
Old Jan 3, 2006 | 09:56 AM
kraimer21's Avatar
http://vbxmaxima.8m.com/tps.html
if that doesn't work, you'll have to go to the dealer to reset the tps with a consult
Old Jan 3, 2006 | 10:19 AM
nismology's Avatar
You can't reset the TPS. If it's faulty it needs to be replaced.
Old Jan 7, 2006 | 12:00 PM
vortechpower's Avatar
I set mine by having the 2 screws loose and once the car was at a good idle tighten them . The tps kinda pivets, you just need to find that special place. No science involved with my proceedure.
Old Jan 7, 2006 | 03:53 PM
gtr_rider's Avatar
192.168.1.1
Would a faulty TPS cause my car to "bump" when i am idling. happens at every stop light.
bump= fall to 550-600rpm shutter and come back up.
Old Jan 8, 2006 | 09:02 AM
maybe a small leak somewhere?(vaccum)
Old Jan 8, 2006 | 09:26 AM
Kevlo911's Avatar
Kevlo for President
Could be dirty tb/iacv.
Does it do it with the AC on?
Old Jan 8, 2006 | 01:23 PM
Im going TPS.
Old Jan 28, 2006 | 06:26 PM
super6's Avatar
yup, adjust the tps!
Old Feb 2, 2006 | 06:25 AM
MDeezy's Avatar
I'm experienceing the same thing except, ( but not at every stop light) it drops to about 200 shutters and comes back up if I dont give it some gas for encouragement. My IACV have never been cleaned since I've owned the car so I assume that is the culprit.
Old Feb 2, 2006 | 12:26 PM
ZeRo MaX's Avatar
is there a "how to" on how to clean the IACV.. i think mine needs to be cleaned cause the car won't start unless I hold onto the gas a bit (couple of seconds) otherwise the car dies on me!
Old Feb 12, 2006 | 10:03 AM
gtr_rider's Avatar
192.168.1.1
I fixed my problem, it was one of my front coil packs. I replaced the front three and havent "bumped' in 2weeks
Old Feb 12, 2006 | 10:18 AM
MDeezy's Avatar
Interesting. So a coil was bad, but not bad enough to throw a cel?
I'm going to clean down the IACV and hope that solves the problem. It occurs once every few days.
If cleaning the IACV doesnt work, I'll look into coils.
Old Feb 18, 2006 | 01:58 PM
95stillenmax's Avatar
Now I have this problem, could it be because it has a 4th gen MAF
mvm062
Nov 30, 2020 09:00 AM
Mar 12, 2020 12:06 AM
I<3 A32's
Sep 10, 2015 11:07 AM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
