Home Made Rear Sway Bar Project - Need Ideas
My cousin and I are trying to fit a 3rd Gen RSB on a 4th Gen and 5th Gen. I pulled the RSb from a 93 Maxima today and cut off the end links. It is very close to fitting but its a couple inches too long. In order to fit on the inside of the rear axle trailing links the way the aftermarket RSB seem to mount, it will need to be about 2.5 inches shorter.
I'm considering a couple options: 1) mount it underneath the RATLs so that the ends can extend beyond the RATLS; or 2) have 2.5 inches cut out of the center of the RSB and welded back together. If it is cut then we may cut it to the right length to fit snugly on the inside of the RATL and just have it welded in.
Anybody have any helpful thoughts?
throw that tiny pencil d!ck sway bar in the trash and buy one that's made for the car.
assuming you work for minimum wage, you could work the hours to pay for a Progress RSB in less time and money than it would take you to make the 3 gen RSB work on your car.
You can get 1 at http://www.customenterprise.com for about $ 55. shipped to your door.
Originally Posted by Wheelie King
OK, thanks. I won't cut it. I will try bending it. It shouldn't take much bending to get it to fit.
Originally Posted by MaximaSE96
ok so 3rd gen RSB like 14mm+/-
Progress 4th Gen Sway Bar 22mm
If it doesn't work then there is no real loss, except for a little time and a little trouble. If I really wanted to save trouble then I'd just buy an aftermarket bar online, take it to the local garage and pay someone to put it on for me. I don't want to rely on off the shelf parts too much without using some imagination. and at least trying something different.
Anybody have a good picture of their aftermarket bar attached to their 4th or 5th Gen? If so then please post it.
MaxStock
Aug 14, 2015 10:03 PM
