exhaust question
Old Feb 11, 2006 | 12:07 PM
JClaw's Avatar
exhaust question
Forgive the FI newb question, but everyone seems to be contradicting each other reguarding exhaust diameter.
Say I threw on an SC kit on my 3.5 and ran very safe boost (base 7 psi), how bad would a 2.5" setup hurt power? I've seen conflicting dynos.
I currently have Cattman headers, hi flow cat and full 2.5" catback. Can anyone speculate the loss from 3.0" to 2.5"? I'm assuming a full 3.5 (heads, cams) boosting 7 psi with stock 3.0 timing would put down something in the neighboorhood of 350whp.
Old Feb 11, 2006 | 05:51 PM
ewuzh's Avatar
If you already have a full 2.5" header-back mandrel bent exhaust, I don't think you will see huge gains going from 2.5" to 3.0" for SCing. It's more beneficial if you're turbo: quicker spool, lower EGTs, higher max boost, more power.
Are you making your own SC mounting plate? AFAIK, the stillen one doesn't bolt on to the VQ35 timing chain cover.
Old Feb 12, 2006 | 01:05 PM
JClaw's Avatar
I swapped the VQ35 using Tilley's method: 3.0 timing chain covers, sprockets, water pump, timing chain and original 3.0 wiring harness/ECU on the 3.5. So the SC kit can be installed EXACTLY as it would be installed on a regular VQ30DE.
Old Feb 12, 2006 | 02:21 PM
liqidvenom's Avatar
brotherhood of tq
do u think that the hp figures u guessed might be a tad high?
Old Feb 12, 2006 | 03:04 PM
JClaw's Avatar
Maybe you're right, I don't know. I was guestimating based on what Z's and G's with SC kits put down at 7-ish psi.
Old Feb 12, 2006 | 03:35 PM
Nealoc187's Avatar
SLOW
Cheapest and best option in my opinion. Keep the setup you've got, add a cutout right after the headers.
Old Feb 12, 2006 | 03:38 PM
JClaw's Avatar
Excellent. Someone else just suggested the same thing to me.
Do you think 350whp on 7 psi is unreasonable given stock ECU, headers, cutout and a custom short runner IM?
Old Feb 12, 2006 | 03:58 PM
diymaximakid's Avatar
i think the stock ecu is whats gonna kill you the most
Old Feb 12, 2006 | 04:26 PM
Nealoc187's Avatar
SLOW
I don't know what the 350zs are putting out with SC because I don't bother to read posts about SC 350zs, but a little ricer math tells me it should be fairly close to that. Maybe like 330 or 340.
Old Feb 12, 2006 | 04:27 PM
Nealoc187's Avatar
SLOW
Why do you say that?
Old Feb 12, 2006 | 04:54 PM
JClaw's Avatar
Please elaborate. I was planning on keeping the stock ECU because the 3.0 ECU timing is very conservative for a VQ35, and acts as already-retarded timing for a 3.5. I was also going to run 94 Octane all the time anyway. This should make for a pretty reliable motor IMO. The A/F is important as ever, but I was planning on leaving the stock timing and rev limiter alone...
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
