Need camber plates....where?
Old Jun 14, 2001 | 11:33 PM
Slickismax's Avatar
I really want a set of camber plates, but don't want to spend $400 for the Ground Control Camber/Caster plates. Where can I find some affordable comber plates similar to what Cattman uses on his coilovers?
Old Jun 15, 2001 | 05:41 AM
AntGVR4's Avatar
Slickismax: sorry to digress but i see you got 245 tires on your car... Do they rub at all in hard cornering ?
Ant
Old Jun 15, 2001 | 06:57 AM
1MAX2NV's Avatar
I think you got hook ups at Stillen. Stillen camber plates are little cheaper than GC.
Old Jun 15, 2001 | 07:01 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Eibach has camber plates for the Max (can be purchased from Stillen).
Old Jun 15, 2001 | 07:14 AM
Screaminfast's Avatar
I though Eibach only made camber bolts for 25 bucks. I believe Stillen makes their version of camber plates, but they're like 200 some-odd bucks. Do the GroundControl ones include the adjustable springs, because if they incorporate the adjustable camber plates, I'd consider getting them.
Old Jun 15, 2001 | 07:17 AM
Y2KevSE's Avatar
I thought Eibachs made Stillen's camber plates? I could be wrong, but I do know Eibach makes the bar for Stillen's RSB.
I'm not sure what GC's kit includes.
Old Jun 15, 2001 | 07:26 AM
no sh*t huh? Eibach makes the bar for the RSB. Are camber plates really necessary, I think not. I think GroundControl coilovers w/ KYB AGXs coming in august will be very comprable to the Cattman coilovers. Of course, without the over top camber plates. You can choose the spring rate for the GC coiloves, and they adjust. Also the struts/shocks are the same. Thanks.
Old Jun 15, 2001 | 08:12 AM
Y2KevSE's Avatar
If you're not slammed, don't worry too much about your camber.
MrBurner mentioned that Cattman might be selling the overtower camber plates for about $600. So:
$400 for Ground Controls (Eibach springs and custom spring rates might I add)
$450 for AGX (I'm assuming)
$600 for camber plates (front and rear)
$400 + $450 + $600 = $1450 which is still less than $1800 for Cattman's Gen2 coilovers.
Old Jun 15, 2001 | 01:44 PM
Exactly...but most peeps here dont even need the camber plates
Old Jun 16, 2001 | 03:30 AM
Slickismax's Avatar
But I am slammed....3" drop riding on bump stops. GC's all the way down, plus 19's. I guess I will just get these:
Old Jun 16, 2001 | 12:49 PM
Slickismax's Avatar
No, just the front. My camber in the rear is fine.
matts95max
Apr 23, 2025 10:44 AM
Dan93se
Apr 7, 2001 02:46 PM
sachin98max
Feb 24, 2001 11:35 PM
I30CeFiRo
Dec 28, 2000 09:25 PM
ZuMBLe
Nov 1, 2000 07:39 PM
