Sponsored by:
Sponsored by: CARiD
95-99 (DE) Block vs. 00-01 (DE-K) Block
Old May 15, 2006 | 08:24 PM
JClaw's Avatar
I know the 2000-2001 internals are lighter, but what about the physical block? Is a 95 block the same as a '01 block?
Does anyone have an article or some kind of document about it? I just want to know if the physical blocks (minus internals) are identical.
Old May 15, 2006 | 09:08 PM
nismology's Avatar
Myth.
Interestingly enough, i just looked it up and the DE-K block has a different part number. Hmm...
But i have read in a nissan technical paper that says the only change in the bottom end is subdividing the grade of the main bearings for less noise and vibration.
Old May 15, 2006 | 09:30 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
I know that the DEK engines have two thermostats. One is for the pistons and the other is for the cylinder heads. In that Nissan paper they mention it helps improve fuel economy. The hole for the secondary thermostat hose is located in the valley of the engine right next to the knock sensor, so to answer the question the blocks are different.
Also cams are slightly different on the DEKs, but DE and DEK cylinder heads have the same part #.
Old May 15, 2006 | 09:33 PM
JClaw's Avatar
I'm asking because I still have my old 95 block laying around and the guy that wants to buy it from me has an S13 with a destroked DE-K block (now a VQ25 that revs like 9000) and he just wants a back up block.
Since he is destroked and is running different internals I assume that means it won't make a difference for him?
Old May 15, 2006 | 09:45 PM
Well if he uses your old '95 DE he will have to use the side coolant pipe from it. The DE and DEK have different pipes, DEK side pipe houses the secondary thermostat and has a hose running to the engine valley. DE does not have that extra piping.
Old May 15, 2006 | 10:10 PM
Nismo3112's Avatar
Custom User Title
You don't have to use that.. VQ35's also have that little chamber. The square chamber next to the knock sensor... right?
Old May 15, 2006 | 10:22 PM
JClaw's Avatar
Pretty sure, yeah.
Old May 15, 2006 | 10:46 PM
IIRC on the VQ35s that square chamber is there but not used. On the DEKs that hole goes right into the water jacket.
Also He doesn't have to use the dual thermostat stuff. He can cap it off on the DEK if he hasn't already and not worry about it on the DE. From what I've read it has some worth so I decided to keep it on my DEK engine swap.
Old May 16, 2006 | 04:57 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What crank is he running?
Any more details or a dyno?
Old May 16, 2006 | 05:04 PM
JClaw's Avatar
He just got the car running. He his class is limited to 2.8 liters so he decided to go with a 2.5.
Old May 16, 2006 | 05:06 PM
IceY2K1's Avatar
What crank/rod combo did he use?
Old May 16, 2006 | 05:32 PM
JClaw's Avatar
I'll ask him. What I know so far:
- 350z Heads, injectors, intake/plenum, face and oil pans.
- New gaskets, oversized rings, bolts, bearings, porting, shaving and honing.
- Grand am Race Cams & Valve Spring set.
Some early pictures (From March I think):
Old May 17, 2006 | 10:37 AM
IceY2K1's Avatar
350Z heads on a DEK block...hmmmnnn.
Old May 17, 2006 | 12:28 PM
JClaw's Avatar
Yeah I'm curious about how he nailed his CR with the VQ35 heads on there.
Old May 22, 2006 | 10:08 PM
TurboS13Hatch's Avatar
Custom pistons most likely..
Old May 23, 2006 | 05:50 AM
Fred Allen Burge's Avatar
Those don't look like Z heads to me....
allen
Old May 23, 2006 | 08:55 AM
Nismo3112's Avatar
Custom User Title
That looks like a DE-K lower.
Old May 23, 2006 | 09:02 AM
nismology's Avatar
WTF? You can see the swirl valve actuators.
Old May 23, 2006 | 10:05 AM
Kevlo911's Avatar
Kevlo for President
350z heads(VQ35 minus pathy) and lower IM are round ports.
Damn just when I thought 35 heads were usable on a 30
I guess he meant 350z headERS
Old May 23, 2006 | 10:09 AM
IceY2K1's Avatar
Not all DEKs have swirl valves....
Old May 23, 2006 | 10:13 AM
Kevlo911's Avatar
Kevlo for President
Mine doesnt
Old May 23, 2006 | 10:46 AM
nismology's Avatar
But 350Z heads means 3.5 LIM, no? I was just saying that the LIM in the picture is clearly a DE-K LIM, or a 99 cali-spec for that matter. Not all DE-K's have swirl valves, but every LIM with a swirl valve is NOT a 3.5 LIM.
Old May 23, 2006 | 12:19 PM
96sleeper's Avatar
Those valve covers also appear to be metal, not plastic.
Old Jun 2, 2006 | 09:09 PM
2slow4u's Avatar
what is the most hp you can put out of the vq30? where is a safe point especially for boost?
shilov
Feb 19, 2024 09:40 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
