Powering-up power windows
Old Jun 18, 2006 | 05:02 PM
semaj3708's Avatar
FEELS GOOD TO BE GANGSTA
Is there a way to power up the motor on a power window directly. The maxima does not have a battery source/power, nor do I have the key anyway. I need to get access so I can remove the window, but it is in an awkward postion and removing the screw/bolt can't be reached.
Old Jun 18, 2006 | 05:11 PM
whitegold's Avatar
Well, if you take off the door trim, and locate the motors, you could just give it 12v of power, should get the motor to do something.
Old Jun 18, 2006 | 05:58 PM
RockfordMax's Avatar
Back from the dead
Why do you have a powerless max with no keys for it?
Old Jun 18, 2006 | 07:08 PM
whitegold's Avatar
Obviously he lost his keys and disconnected the battery for long term storage
Old Jun 18, 2006 | 07:09 PM
Back from the dead
Or it's stolen......Odd circumstances.
Old Jun 18, 2006 | 07:26 PM
whitegold's Avatar
I just dont understand why you'd want to roll down the window... If you can access the window motor surely you can access the engine bay?
Old Jun 19, 2006 | 05:04 AM
MIXXMAX's Avatar
It seems like he wants to remove the window from the door. To take off the door panel, the window must be in the down position anyway. Once the door panel is off, you can access the window mounting screws by slightly raising the window up thru the frame openings of the door and removing the bolts. There are only 2, and the window slides right out.
Old Jun 19, 2006 | 02:58 PM
semaj3708's Avatar
I just love the speculation. It is a wrecked Max that I picked up for spare parts. I know how to remove the panels, heck I know how to remove just about everything from the car, but when it comes to electrics I'm a little shy. The windows are half down position and I need to get at the screws, but can't. Hence the whole reason for the title. Can anyone point me in the wrong direction.
Old Jun 19, 2006 | 03:25 PM
Back from the dead
Haha I believe you, i was just messing around. Lets see... You could try to unbolt the entire motor assembly from the door, track, motor, and everything.... If you don't need the track assembly, cut the cable.... Or like someone above said, Get a battery, and just connect + and - to the terminals on the actual motor to try and get it moving.
Old Jun 19, 2006 | 03:41 PM
semaj3708's Avatar
I'm really trying to save the regulator too(mo' money). I'll try the batery thing tommorrow, thanks.
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
