OEM Spoiler Install
Old Jul 8, 2006 | 09:31 PM
Will's Avatar
OEM Spoiler Install
Yes, 200th post after over 5 years!
Holy moly, I was at the boneyard today, and scored a black nerfy OEM spoiler that came off clean on the sides, and still had all 4 8mm nut studs in the middle intact, WITH a harness!
Now my question: I have a GXE trunk. Is our brake light system in the back pre-wired for that harness, or am I looking at more intense wire work? Thanks in advance!
Old Jul 8, 2006 | 11:21 PM
Hectic's Avatar
i'm sure the wires which go to the rear deck light are the the ones you'll want to redirect to the spoiler...
Old Jul 9, 2006 | 05:30 AM
«§»Craig B«§»'s Avatar
I dont think it would be prewired, but I could be wrong. If it is, there will be wires running up one of the trunk hinges (drivers side I think). But I think there is also wiring there for the trunk latch switch (to tell if trunk is open).
But like Hectic said, even if it's not pre-wired, it wouldn't be that hard to extend the wiring from your current 3rd brake light. Just two wires there. Crimp new wires to it, run it up the hinge and to the spoiler light.
If you go this route, it might be a good idea to go to the junkyard again and cut the harness out of a SE. This way you'll get the connector so the spoiler wont be hardwired in and can be removed later if necessary. And you can get a couple feet of wiring probably.
Old Jul 9, 2006 | 05:54 PM
andy044's Avatar
RWD bolt-on conversion?
has everyone one came to an agreement with the best way to reatach rusted spoiler is yet?
thread pirate here
Old Jul 9, 2006 | 07:39 PM
Michael's Avatar
Back in a 3rd Gen.
Will it would have been easier to just get the whole trunk instead of drilling the holes for the middle and especially the sides...unless you are just going to glue the sides down.
andy044 I have heard that liquid nails is the stuff to use but I have no experience with it.
Old Jul 9, 2006 | 10:39 PM
traxtar944's Avatar
Would be lost w/out the org
thread pirate here
I posted a mini-writeup about how I did mine. It's a cheap option that works pretty well with some 3M tape or other adhesive.
http://forums.maxima.org/showthread.php?t=475756
Old Jul 9, 2006 | 10:52 PM
traxtar944's Avatar
Oh yeah...back to the topic at hand.....the GXE trunk is not wired for a spoiler if it didn't previously have one. However, like everyone else said it's pretty easy to run some wires. I'm pretty sure you could just splice some wires in from the brake light thats already in your car without trouble. Then you'd have 2 third brake lights, but thats no big deal I guess. At least nobody would rear-end you because they couldn't see you, lol.
Old Jul 10, 2006 | 06:40 AM
Michael's Avatar
Back in a 3rd Gen.
oh yeah I forgot that GXEs had the window brake light. DO NOT leave it hooked up with the spoiler light. It looks bad if you do that (attention to detail). So what you do is find where the deck light is plugged up and cut and splice the wires from there.
Old Jul 10, 2006 | 07:38 AM
vansskaterfreek's Avatar
to re-glue my spoiler down on my 1991 SE, i used liquid nails, and after a full year, it has not started to come up at all......all you have to do is clamp it down hard to the trunk lid...... as with the wiring, i never owned a GXE.. but i would say it isnt wired into the trunk because it was not an option on the GXE....(i think)...but it really isnt that hard to extend your wires to the trunk... i think it may be 2 wires....
Old Jul 10, 2006 | 10:17 AM
Duckman540i's Avatar
VE Powah!!!
What glue do you think would work best to keep the spoiler down?
#1 Gorilla Glue
#2 2500 PSI Epoxy
#3 Liquid Nails
Old Jul 10, 2006 | 02:27 PM
GRNMAXDMON's Avatar
i would go back to the junkyard and get the damn trunklid so that i don't have to drill holes on my existing trunklid.
Old Jul 10, 2006 | 02:57 PM
goon9's Avatar
#1 Gorilla Glue
#2 2500 PSI Epoxy
#3 Liquid Nails
Or #4 drop it in a 55 gallon barrel that Batman dropped Joker in.
Old Jul 10, 2006 | 07:57 PM
+1 for the liquid nails since i know it works.....
Old Jul 13, 2006 | 11:27 PM
VE Powah!!!
What did you do to keep it down with the liquid nails? Did you just apply some to the bottom edges, and let it dry with some C-clamps? That's what I'm thinking.
Old Jul 14, 2006 | 04:34 AM
Will's Avatar
Thanks for the opinions gents. I was thinking double-sided-tape because the ends came off so damn clean. Also, when I saw it at the wreckers, the trunk was not black, and it was dented from the guys working at the wreckers.
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
cstrasz
Aug 27, 2015 08:07 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
