After installing UDP
Old Jul 31, 2006 | 06:59 PM
MaximaRacer_95's Avatar
does anyone notice a sound change of the engine after installing UDP(unorthodox pulley)? ...it sounds like a G-35 exhaust or something similar, not loud but noticeble. Is this normal?
Old Jul 31, 2006 | 07:03 PM
NmexMAX's Avatar
dot dot dot ...
It's probably the G35 spoiler you have.
I do not see how a pulley would affect the sound of the exhaust:
Old Jul 31, 2006 | 07:04 PM
the funny thing is that i dont think its coming from the exhaust, its from the engine bay.
Old Jul 31, 2006 | 07:07 PM
NmexMAX's Avatar
dot dot dot ...
So... how does the G35 sound different from the FWD VQ35...in the engine bay?
Check your work and see if everything is installed correctly.
Old Jul 31, 2006 | 07:20 PM
i meant that the sound that is coming from my engine bay sounds like a G35 exhaust only at certain RPM levels (around 4k-5k).
everything is fine. belts arent loose or anything.
Old Aug 1, 2006 | 10:18 AM
madmik's Avatar
Belts could be too tight.
Old Aug 1, 2006 | 12:22 PM
how do i figure out how much to tighten or to loosen?
Old Aug 2, 2006 | 05:34 PM
madmik's Avatar
Apply 22 lbs in middle of belt (or pull using a fish scale). For alternator, deflection should be at most 0.16 inch for a new belt. For PS, max deflection is 0.28 inch. Its not much. Over tightening is hard on accessory bearings. Stay a tad on the loose side. If you turn on the A/C and the belt squeaks, then it too loose.
Check maintenance section, p:12 of service manual. Download a free copy from http://www.phatg20.net/modules.php?n...titleA&show=10
Old Aug 2, 2006 | 08:44 PM
i used two fingures and pressed it down. it goes abt a half inch down with a little force( id say abt 25lbs to 30lbs of force). Is tht ok? Dues told me 1/2" should be fine but didnt tell me with how much force.
Old Aug 3, 2006 | 03:13 AM
DeusExMaxima's Avatar
I tightened mine to the point just so belts dont squeal. Initially, there was a slight squeal, so I tightened it slightly until squeak went away. This makes sure they arent overtightened. The rule of thumb is 1/2" deflection when u press down the belt in middle of the accessories.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
