Weighed my SE 17" wheels today! Oh my god ----
Russ, My Borbets are 52lbs with Tires but My car got slow once I replaced my factory rims with these. Must be the OffSet, Plus it pulls to the left and right now more then it use to, but then again I didn't have all the HP with the stock 17z
Originally posted by WILLSE
the rims are not that heavy weight the rim without the tire it is not heavey at all for a factory rim! i was shocked!
just playin with ya
That's about what I thought they would weigh. They look really heavy. I bet those tires are pretty heavy too. You should look into some lighter rims because those things are sucking about .2 out of your et. My 17s weighed about 48lbs and when I would swap them out for the 41lb 15" stockers, I dropped about .2 and gained 1.5mph.
Dave
Dave
My 17" Epic rims and tires weigh 50lb's each. I did quite a few runs with my G-Tech pro from 0-60 with and with out my 17' rims. The tests were on my 5spd 95 max. The best time I got 0-60 with my stock 15's was 6.13 to 60mph but I usualy average about 6.2-6.4. I then tested my 17's and on the 2 runs I got 6.98 and .6.99 which equates to about .6 second loss from 0-60.
On another note I am convinsed that the 2K+ Maximas are faster then 95 maximas given the same stock 15' setup. If you noticed the tests from MT on a 95 Max did 0-60 in 6.6 on the stock 15' setup, now the MT test on a 2K Max used heavier 16's{SE} and got 6.7 to 60mph. Point being if a 2K had stock 95 SE rims it would probably have run a 6.5 to 60MPH.
Originally posted by Paul2kGXE
Hmmm... love the looks of my new 17's, but the weight isn't great. Anyone want them.
No.. still thinking it through. I've noticed that my car is a little slower off the line though. They are 6-10 pounds heavier than the 16's, so I think what I'm feeling is real. Handling has slightly improved though.
Right now I have 8 nice rims with new tires. I have my 5 spoke 16's stacked in my basement awaiting my decision.
Originally posted by UMD_MaxSE
Getting rid of them so soon? I think I will keep mine until the tires wear out. Then, I will probably go with a new set of light weight rims
Your are correct. I'm probably the only person on Maxima.org that's has owned all 3 rims.
GXE (old GLE) luxury rim 215-55/16
SE/GLE 5 spoke sport rim 215-55/16
SE 6 spoke sport rim 225-50-17
Originally posted by Punch84
The 5-spokes are the same size as the 9 spoke right? I hope so cause then I can switch the tires. Just need to find some...
How much for the 17"?
thanks
That is why most think there maxima is slower than '00 models
If you were to look back, you would see that most (maybe all) of the car magazines tested the '00 maxima with the 16" wheels -17" came out late. The smaller diameter/lighter wheels yield a bettter 0-60 time. I bought my SE with 16" wheels (no C&C) and I have beaten 2 '01 se 5-spd maximas with 17" pretty easily. You would be suprised how the lack of the weight from sunroof, power seat, wheels/tires, leather, and aero kit helps the performance.
