Why does my Maxima shift hard into 2nd gear?
Old Aug 15, 2006 | 08:13 AM
nathan91tt300zx's Avatar
Hey guys 80% of the time when driving spiritedly the Maxima bumps hard into 2nd. Have any of you had this and if so WTF???? Is it one of the Motor mounts or something????
-Nate
Old Aug 15, 2006 | 08:25 AM
davey6693's Avatar
Hard shift = normal. I don't mind it anymore. Synthetic ATF helps, but that shift is pretty efficient as far as acceleration goes.
Old Aug 15, 2006 | 08:26 AM
Guys please help because this is the car that I am leaving with my family while I am in Afghanistan for 14 months and I leave soon. I want to make it perfect before I leave. When I am there I will be cut off from the rest of the world until my time is up.
I appreciate all help that anyone offers.
-Nate
Old Aug 15, 2006 | 08:28 AM
Are they all like that??? It seems a little rough to me. I would think that a smoth effortless shift would be better on the Tranny and for times.
-Nate
Old Aug 15, 2006 | 08:40 AM
RedfoxXx's Avatar
cuz 1st to second is the most used shift and you’re cars old like all of ours, its normal, just don’t flush the fluid if it hasten been maintained maybe try replacing ¼ of it
Old Aug 15, 2006 | 09:08 AM
Thanks for the advice. Yes it has recently been flushed but the car was always well maintained. It has done the hard shift thing since I purchased it.
I just thought that maybe it was a worn motor mount or bushing somewhere that does it.
-Nate
Old Aug 15, 2006 | 10:23 AM
ajcool2's Avatar
Yup mine does the same I'm used to it. I got 137000+ on the clock.
Old Aug 15, 2006 | 12:05 PM
nitink's Avatar
-Nate
Nate, 1) Check that tranny is not overfilled
2) If fluid is in good condition, you can try to add Lubeguard Red (one bottle) , It should do wonders.
Good Luck with your trip to Afganistan. Wish you a safe & Sound return back to US.
Old Aug 15, 2006 | 12:40 PM
zeeman's Avatar
it could be the resistor assemly for the tranny. I changed one from another maxima and it was much better than my original one but still had tiny hard shift from 1 to 2 shift when its cold. I m tryting to buy a brand new one from nissan.
Old Aug 15, 2006 | 01:33 PM
ajcool2's Avatar
The drop resister?
Old Aug 15, 2006 | 02:00 PM
Thanks a million!!!
1) Checked the tranny fluid and it is spot on.
2) It was changed 3-4 months ago by Nissan (A Master Mechanic that know I trust).
Thanks again, I hope to return safe and sound. Although, I would die for my country I would prefere making the enemy do so instead.
-Nate
Old Aug 15, 2006 | 02:01 PM
Where is this tiny resistor assy located. I have a maintenance manual I am going to go and check.
-Nate
Old Aug 15, 2006 | 02:02 PM
Originally Posted by ajcool2
The drop resister?
The drop resistor, thanks...
-Nate
Old Aug 15, 2006 | 02:28 PM
zeeman's Avatar
some people call it drop resistor and some call it the resistor assembly. Cheapest one i found was 56 bucks from dealer.
Old Aug 15, 2006 | 03:50 PM
CRiME's Avatar
oem ftw!
it's located on your driverside strut tower, kind of hidden by the airbox. in another post, someone identified it as nissan part number 31037-71L00 . I think i'm going to try locating a brand new one too to see if it helps this problem.
Old Aug 15, 2006 | 06:02 PM
You guys are the ****.... Thanks so so so much...
-Nate
Old Aug 15, 2006 | 06:03 PM
Awesome, my salesman at the stealership gives me parts at cost so I will check with him tommorrow.
Thanks,
-Nate
Old Aug 15, 2006 | 06:36 PM
Supermax95's Avatar
tranni's that shift hard are not nearly as ones that shift slowly......if your car has a lot of miles you;; just have to deal with it....
Old Aug 15, 2006 | 06:54 PM
I apologize but I don't understand what you are trying to say here. They are not nearly as what?
Again I am not trying to sound rude just didn't get what you posted and am hoping for some clarification.
-Nate
Old Aug 15, 2006 | 10:54 PM
CRiME's Avatar
oem ftw!
No problem man, be safe in Afghanistan. All the best.
Old Aug 16, 2006 | 07:21 AM
Thanks, I will do....
-Nate
Old Aug 16, 2006 | 03:30 PM
Supermax95's Avatar
-Nate
I meant to say scary......Tranni's that shift slowly are the one's that really need to be worried about.
Old Aug 16, 2006 | 05:10 PM
QnzMax's Avatar
Mine does the same thing and it only started happening after i had the tranny rebuilt.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
maxima-junky
Aug 13, 2015 09:59 AM
MikesChevelle
Aug 10, 2015 10:53 AM
