tire height question??
Old Oct 6, 2006 | 12:36 PM
cyberg21's Avatar
I am considering purchasing 245/50/18 tires for my MAX, can anyone give me some input as far as me running into any issues, (performance problems or tire clearance issues)?
is the difference from the stock 245/45/18 to 245/50/18 that significant that it might cause problems?
thanks for you help!
Old Oct 6, 2006 | 01:41 PM
!PrjctMax!'s Avatar
245=the width of the tire in mm
45=45% of 245 as the sidewall
18=size of tire
So going from a 45 to a 50 would just result in a thicker sidewall, which would result in a slight decrease in handling turns but a slight increase in ride quality.
Old Oct 6, 2006 | 02:11 PM
RHMax's Avatar
Newbie just Registered
Why would you not get tock size? It would throw the speedometer and odometer off. Thicker sidewall would most likely mean softer ride and handling. As far as clearance, the tire would be about 1/2 thicker and 1 inch taller.
Old Oct 6, 2006 | 03:43 PM
MDS's Avatar
MDS
RHMax is right on. A 245/45/18 is 26.68 inches tall. A 245/50/18 is 27.65 inches tall. That is a 3.62% increase in the tire height. At 60 mph, it will throw off your speedometer by 2 mph. If your speedometer reads 60 mph, you'd actually be going 62 mph. The taller tire will also flex more in turns and hurt the car's response and handling.
Old Oct 7, 2006 | 09:02 AM
cyberg21's Avatar
tires
thanks for the input guys!!
Old Oct 13, 2006 | 03:10 PM
Caster Troy's Avatar
http://www.cardomain.com/member_page...12_32_full.jpg
MR2 T'd
Jul 9, 2021 05:06 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
