B&M supercooler??
B&M supercooler??
I just bought and installed a B&M supercooler tranny cooler model #70268. I saw a write up on here about how to install this, but it in the write up they keep using the stock cooler. I found it alot easier not to and was wondering if thats ok to just use the B&M? Will it be enough if I were to say spray some nitrous? Or really beat on my car at the track??
Originally Posted by Chunger
Should be fine to run without stock cooler in the radiator because the B&M should have much greater heat dissipation... but you could also run it AFTER the stock one.
Originally Posted by Cdg2125
Cooler should be mounted in front of the radiator so to get the most cold air. Should be able to mount it to the radiator with supports and some padding.
nick
May 17, 2009 10:33 PM
deezo
Oct 16, 2002 10:30 AM
