LTB 2 Install Advice/Help
Old Nov 10, 2006 | 07:47 AM
machinehead131's Avatar
I am planning on installing a LTB 2 from blemco and have heard it can be a bit difficult without access to a lift.
I really wanted to do this, is it as hard as it seems?
I don't have a drop or any other suspension modifications, starting with this and the RSB.
Thanks for the input
car is a 2003
Old Nov 10, 2006 | 07:49 AM
SoonerFan's Avatar
Cletus
you should be able to do it with a jack and jack stands
Old Nov 10, 2006 | 07:51 AM
zero2sixtyZ's Avatar
You embarrass me.
+1. Just make sure you have the right tools.
ok, that is what i thought - i talked to someone on the org who said it is hard to line up the bolts and he stripped one...
Old Nov 10, 2006 | 07:52 AM
where should i jack on the front mound and let the car sit on the stands?
Old Nov 10, 2006 | 08:00 AM
SoonerFan's Avatar
Cletus
its right behind the front wheel wells. you will see a notch.
you will probably need liquid wrench for the bolts...i know i did.
Old Nov 10, 2006 | 08:03 AM
You embarrass me.
they are really hard to line up. make sure you torque them to spec, I think I over tightened mine, and now it is creaking.
Old Nov 10, 2006 | 08:04 AM
Two people would help in lining this up, would it not?
Old Nov 10, 2006 | 10:04 AM
super6's Avatar
cant u just use ramps? or do the wheels need to be off?
btw, u should really consider a suspension if ur getting the brace.
Old Nov 10, 2006 | 11:34 AM
ktranne's Avatar
NOOB
just got them on yesterday.
it's easier to take the front wheels off.
It's easier if you have someone help you.
It's a PITA if you have automatic like me.
Old Nov 10, 2006 | 10:17 PM
Have a 6 speed no ramps but do have jack stands - i am doing springs a month after this install.
Old Nov 11, 2006 | 07:47 PM
chr0nos's Avatar
the control front control arm bolts were a pita to get back on mine. i had to use two sockets. one was put on one bolt, then the other on the other bolt. then the whole ltb mounted. i could not get one of the sockets on, if the ltb was in place.
Old Nov 11, 2006 | 09:06 PM
You embarrass me.
Anyone else have a creaking noise once they installed theirs?
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
