Strange Engine Noise
Hi Folks,
I just started noticing sort of a friction noise
coming from under the hood. Very loud, even
at Idle rpm.
Sounds just like when you apply the brakes and
you have awfully worn-out brake pads, you know..
that metal rubbing metal noise.
Some times you step hard on the gas and it
goes away. Any ideas?
Regards
BrazilianMax
at Idle rpm.
Regards
BrazilianMax
Can you smell burning rubber or see smoke? It could be a belt rubbing. Or maybe something with your alternator. Does it happen with the heat and/or AC on? Does it change pitch with RPM's?
Engine noise
Remove the belt(s) from your engine and start it up long enough
to see if the sound has gone away. It it's gone, you can spin the various
pulleys by hand to see if one feels like it's not smooth.
Good luck,
SJ
Good luck,
SJ
ballerchris510
Sep 11, 2015 05:29 PM
