help no power getting to starter
help no power getting to starter could it be factory alarm related
my ignition is getting power but im not getting power to the starter, does anyone have a wire diagram to where the wires run from the ignition to the starter? I can use a jumper wire and start the car that way but when i use a test light it im not getting power. I pulled the factory alarm fuse cause my key fob wont stop the alrarm form beeping. could the alarm disable the starter? thanks
Brandon
Brandon
Most likely it's the ignition switch, a common failure item in our cars.
Check all the fuses and make sure you don't have a relay gone bad.
For $15 bucks the Haynes shop manual has complete wiring diagrams to help you troubleshoot.
maxima297
Sep 30, 2015 03:32 PM
