Can't seem to figure this one out... need advice
Okay so I bought my Max in March 06'. The previous owner (505max) had hit a median/curb and shattered one of the wheels. From then on the car slowly started making a vibration noise somewhere up front. It's been getting worse and worse to the point where now it is very loud and the steering wheel shakes about a 1/4" to an 1/8" back and forth at lower speeds now. So far I've replaced the driver side wheel bearing, hub and CV axle. The noise sounds like its coming from the driver side front. I dont know what else to check. I've checked for play in all the steering components and there's none. Tie rods maybe? I'm about to give up and take it to a shop and have them do a diagnosis on it which is hard for me to do, I disagree with taking my car anywhere. Any ideas or advice? thanks.
damaged driver side control arm prolly bro i remember in my maroon 93 se i hit the curb front end over the crub and bent both control arms bro might check into the control arms being damaged how does the wheel look does it look closer to the rear of the front tire well or what?
The tire on that side may defective,the steering wheel shake/shimmy you speak of is consistant with what a bad/severely out of balance tire would do...
A bent control arm could be responsible for the damage to the the tire,but i dont think it is causing the actual "shimmy" itself...
I just had this problem with my car. The wheel would rock back and forth
at low speeds and would smooth out the faster I went. I thought it was
out of balance tires or a broken belt. I was getting gas one day and thought
the tires needed some air.Each tire had about 20 psi of pressure,so I pumped
them up to about 38ish and the wobble went away. Hope it's just that simple for you,and if not I would check for out of balance or broken belts. gl
I know it has nothing to do with tires because I've swapped the wheels and tires recently and no change. Also it's not just a shimmy problem there a rubbing/scraping/banging kind of sound with each revolution of the wheel and the steering wheel moves which each sound. I'm not sure how to check the tie rods and ball joints, I know there's no play when I move the tires back and forth and the ball joint isn't flimsy or sloppy it actually seems pretty decent.
I did the same thing in my old Acura, and the control arm was bent. I constantly heard a grinding noise in my car. I know it's not a Maxima, but I thought this info might help.
Quick question on my Maxima. Rear Defrost doesn't work. Light switch on dash works, fuses are fine. Ideas?
Also, I never get a straight answer on how many quarts of oil actually go into my car. 3 or 4? I have a 3.0 sohc v6. I assume it's 3 because I have a 3.0 liter. help!
One last thing: How important is it to warm-up my maxima in the morning? Rule of thumb for me is about 2 or 3 minutes.
Well here's a couple videos, I jacked it up and let the wheels freespin and now it sounds like its somthing in the passenger side knucle region. Just looking for some last minute suggestions before I tear it apart. thanks.
http://s143.photobucket.com/albums/r...t=P1080003.flv
http://s143.photobucket.com/albums/r...t=P1080002.flv
could be anything on the suspension that's bent....
knuckle, tie rod end, warped brake rotor, bent control arm, bent axle...
I'd look for something bent in the rotating assembly... axle or wheel bearing/hub.
I've also had this exact problem recently on my chevy pickup.. bad brake line causing the fluid to not discharge from the caliper upon brake release. this caused the caliper to rub on one section of the rotor and eventually caused a SEVERE warpage and vibration issue while driving... new brake line, caliper, and rotor was required before the problem was solved (because I kept driving on it and ruined everything)
So you did actually islolate the sound to the passenger side of the car?? I thought it was the driver side?? The wheel that I broke was on the front, driver's side of the car and I really don't think that caused the problem. I broke the wheel because a median was sticking out into my lane. It was complete BS... After I broke the wheel the alignment was still good and there wasn't any vibrations... Which axle did you replace??
I've replaced everything that rotates on the driver side. In the car it feels like it's on the driver side but out side it sounds like its on the passenger side. Unfortunatly it's almost undrivable now. Which side broke when you did that reverse burnout?
typical texan
Originally Posted by 505max94se
I never did a reverse burnout... I did break the passenger side axle, but I replaced it... The problem wasn't there when I sold you the car and I doubt it has anything to do with how I drove the car. It almost seems like it's the passenger side axle support bearing. I can't really help too much because I'm not there, I wish I was... You should have a good mechanic take a look at it.
on the support bearingI had the same problem when I bought mine, and it steadily got worse. It was completely shredded by the time I found it. Replaced the shaft, and it ran perfectly after that, no vibrations.
Damn, I had a spare support bearing too. Check NWmaximas, Tony might have an extra. I sold him my spare VE30DE. It had one attached when I sold it and I don't think he needed it. Maybe MrGone has one still?
You drive a Cheby?
typical texan
typical texan
I have a beater truck for hauling stuff around. I wouldn't say I drive it... I've put maybe 1500 miles on it since I got it 1.5 years ago- and 500 miles of that was the drive home.
I had that same problem and took it to the local tire shop. it turned out to be the tire belts were coming apart insite the tire.
they said I didn't have too much longer untill it would have blown out. I was pleased to find out it was someting that simple.
put your spare on the front on the side that took the brunt of the crash and see if that is it.
Sounds like backpedaling to me
but yeah.. I own it.. I drive it when I have to. but it sits in the street 360 days of the year.
fx4five
Oct 18, 2015 06:57 PM
