Weird engine miss - vg
Old Jan 6, 2007 | 06:33 PM
redwood_usa's Avatar
My car starts and runs well from cold - But if I go a long ways and park for a little while it starts missing badly when I restart it. Or if I go a short ways and park in the hot sun (texas in july), it does the same . Any one with some ideas.??
Old Jan 6, 2007 | 06:57 PM
dafiremaster's Avatar
have a mechanic throw a timing light on it. Also other things to check would be the spark plugs/ignition system. or a vapor lock issue.
Old Jan 7, 2007 | 03:59 AM
Vapor lock ???
I initially thought that it was a vapor lock, but all the reading material on the net says that vapor lock is a thing of the past with fuel injection engines. Could a failed gas cap do this ?
Old Jan 7, 2007 | 04:02 AM
Greeny's Avatar
¯\(°_o)/¯
You have got to be joking? right?
Old Jan 7, 2007 | 04:04 AM
Greeny's Avatar
¯\(°_o)/¯
Have you done a tune up recently?
Old Jan 7, 2007 | 04:53 AM
Fuel injection has cut down on the vapor lock problem, but it can still happen. How long has it been since you've changed your fuel filter? also you might have some water in the fuel lines. My car has a similar problem, which i've not yet figured out. I can only get it do to it sporatically. It got to the point where i hadnt drove the car at all and my fire department got a code red shooting call. Well it ran like crap. trying to get to the call, and then died on me at the scene. Boy... that was an interesting day. I'm hoping the problem shows back up in the summer, so i can take care of it. Though, with future plans to the car, that problem may not be an issue any more.
I've never had any experience with a failed gas cap, but i've been told before that fuel injected cars run like crap without a gas cap on. so i suppose that could be a problem.
Old Jan 7, 2007 | 04:56 AM
No... i'm not joking. Timing can cause an engine to miss. Though typically when the engine is cold. I've seen cases where it affected the engine when it got hot.
If the engine is missing, the ignition system is a no brainer to look at.
Old Jan 7, 2007 | 05:10 AM
Assuming I have some water in the fuel lines - how do I get rid of it ? I did a tune up of everything else about 3 months before this problem started. New sparks, wires, air filter, fuel filter, cap.
Old Jan 7, 2007 | 05:54 AM
Greeny's Avatar
¯\(°_o)/¯
I was referring to the vapor lock theory dude..Welcome to 1985..
On fuel injected cars the gas is constantly circulating from the tank, through the system and back to the tank. The fuel does not stay still long enough to get so hot that it begins to vaporize.
Old Jan 7, 2007 | 07:51 AM
internetautomar's Avatar
mod or sell?
There is no vapor lock because the fuel is under pressure from the time it leaves the tank.
Vapor lock occurs only on vehicles without an in tank pump.
Old Jan 7, 2007 | 11:04 AM
It still can happen! water in the lines, If the fuel filter is clogged, under heat it will produce a similar type occurance.
To get water out of the lines, run the tank about empty. Put 3-4 bottles of isopropyl alcohol in it and run it till it dies.
Old Jan 7, 2007 | 11:24 AM
Greeny's Avatar
¯\(°_o)/¯
Quick! Logout.....
Old Jan 7, 2007 | 03:22 PM
mod or sell?
uh huh, let me guess you went to mechanics school right?
Old Jan 7, 2007 | 04:33 PM
goon9's Avatar
It's called A-tech skool now right? Just goes to show that some shops still pay more for ppl with experiance than schooling.
Anyway. If there was moisture in the line(which I think is bs because Internetautomart is correct). But IF, it would run like crap ALL the time. It's only doing this after warm up.
Knock sensor? I know they tend to cause problems after warm up.
And about timing. I've set my way retared and advanced, and never missed. The only time was when I was 180 off.
When I ran into a problem like this before, I changed my cap, rotor, plugs and that solved the problem.
Old Jan 7, 2007 | 09:11 PM
Alex_V
Test your injectors and run some marvel mystery oil and a bottle of techron additive with 1/4 of gas or less. If you tuned up your cap and rotor recently any way.
~Alex
Old Jan 8, 2007 | 06:55 AM
Solved the problem. It was the oxygen sensor.
Old Jan 8, 2007 | 07:06 AM
Greeny's Avatar
¯\(°_o)/¯
The sensor was vapor locked..
Old Jan 8, 2007 | 08:26 AM
:-)) Aparently the sensor was not working for a long time and the engine was running really lean when hot ? It was a lean misfire. The battery must have been disconnected for some service after the sensor failed and the ECM never learnt eh right mix for a really hot texas summer.
conansriver
Nov 18, 2015 02:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
