buget Ypipe.
buget Ypipe.
im wondering what size piping is a buget yipe and what type of gain I should see on the dek with it. And what size cat back should i get and whats a good one?
are you using the 4th gen manifolds or 5th gen manifolds? the 5th gen manifold has the pre cats built into it, so the gains wont be as good compared with the 4th gen manifold. The 4th gens pre cats are built into the y-pipe so replacing the y-pipe with an aftermarket gives gains similar to headers on a 5/5.5gen. I believe on my y-pipe(CP) it was 2.5" but then again i never really measured it. A 2.5" catback is more then sufficient for a N/A engine, anything larger will result in a loss of low/mid end power.
as for power gains, if your using the 4th gen manifolds id expect similar gains, maybe a little more, if your using the 5th gen manifold id expect less maybe 8-10WHP?
Originally Posted by ethnic6
I've got a budget, love it... when ur buying a y-pipe, they all give u the same gains, its just the name that ur buying, much like a front strut bar
Originally Posted by venompwr2
I found this a little odd, but you did a dek swap and arent sure which manifolds you used?
Ceasars Chariot
50
Mar 2, 2005 01:10 PM
cmist11
Sep 30, 2004 04:49 PM
jimkim2004
Apr 24, 2004 07:13 PM
BigDogJonx
Jan 9, 2003 09:10 AM
