strange hissing sound on passenger side
On the very very far right side of my car, there is a hissing sound that is DIRECTLY proportional to how hard i am on the gas. Very prominent when climbing a hill without kicking down any gears (so the engine is still quiet). Passenger can not hear the hiss with their left ear either. I will try and get a video; my first attempt failed to capture the sound, as far as i can hear. I'll try again tomorrow.
So far i have been suggested that it could be: exhaust studs, vaccuum leak, or my alternator dying (? got me?).
Point is, regardless of engine RPM, the sound gets louder just by me pushing the gas pedal, not by an actual increase in RPM. I can be using plenty of gas up a hill while losing speed slowly and hear the sound loudishly, and coast down a hill picking up speed while hearing no hissing at all.
Ideas?
Ideas?
Originally Posted by 92 Max
It's definitely a vacuum leak. Does this hissing occur in the passenger compartment or the engine compartment?
Originally Posted by gapboi210
does all the vent settings work on the a/c? wonder if a vacuum line broke. thats the only thing i could think of that might be using a vacuum in side the passenger compartment
Yes, I second this. The engine vacuum will rise and fall with engine speed and load. The doors and such on the heat/AC system use vacuum to open and close them. Put your head under the glove box and you probably will hear where it's coming from. Replace or repair the leaking vacuum motor or tube.
the way i found my vacuum leak was by checking all the vacuum lines....as there is a vacuum diagram on your hood most likely.
but another way you could do it is to open your hood, start your car and go stant in fron of it near the hood, and try to pinpoint it...and if you need less engine noise while doing so, just have a buddy turn the car off while you look, sometimes it will last longer than the engine noise with the pressure rising to zero.
well i know it's an exhaust leak b/c i saw seafoam fumes eminating from my ypipe just after the joint... which listening to the sound it makes sense because it sounds like a very faint version of a straight-pipe muffler.
i've never really had to search for a exhaust leak, because all of mine have been bad enough to basically spot easily.
couldn't you use a technique similar to the one used to cheak for leaks in tires? coat with soap and water and watch for bubbles?? while the exhaust is cold BTW. haha it was worth a shot.
just throwing that out there. lol
Originally Posted by capedcadaver
my seafoam sucky port
still don't see what you're saying though.
just make sure you don't hydrolock your motor
love the terminology on the org. haha
sure. lol alright. as long as you're taking care of it, because you lost me
basically if I had not begun searching for a VACCUUM (just caught the typo) leak, I never would have looked around at that vaccuum line, and thus would have never bothered seafoaming probably. However, that seafoaming is what eventually led me to find the exhaust leak, due to seafoam fumes escaping from the ypipe itself.
oh ok, that's where i got lost...wasn't sure what a VACCUUM line was.
broken stud = exhaust leak + over time = carbon deposits (such as just below the SAN) :
don't mind the rest of the dirt there.
Maxima30
Sep 7, 2015 06:13 PM
