Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
What can be causing excessive noise?
Old May 27, 2007 | 10:53 PM
!PrjctMax!'s Avatar
My rear end has been having some excessive noise lately. I lubed up the sway bar bushings and it got a little quieter, but it is still noticeably annoying. What else could be causing this? I am lowered on Progress springs and have KYB's all around with Racingline end-links.
shock mounts, the rusty end-links, other bushings, what can it be?
Old May 28, 2007 | 04:14 PM
!PrjctMax!'s Avatar
Are the suspension gurus not here today?
Old May 28, 2007 | 04:46 PM
irish44j's Avatar
retired moderator
you need to be more specific about the nature of the noise and try to get a more specific location for it before we can help, and describe when this noise happens (turning, straight, braking, going over bumps, etc..)
"noise from the back of the car" could be anything from a blown strut to your emergency jack not locked down securely.
Old May 28, 2007 | 07:06 PM
!PrjctMax!'s Avatar
ALL of those... which is why I am baffled with this crap! And wouldn't it be a blown shock in the rear?
Old May 28, 2007 | 07:14 PM
Kevlo911's Avatar
Kevlo for President
Bushings on struts bad? Strut bolt loose?
Old May 28, 2007 | 07:48 PM
!PrjctMax!'s Avatar
How though?! car has only 34,xxx miles on it. Could it be that it is lowered? Could it be a bad shock mount?
Oh, and the noise is equivalent on both sides in the rear if that tells anyone something.
Old May 29, 2007 | 06:46 PM
!PrjctMax!'s Avatar
Can it be that my rear shocks are blown? I noticed today that in a turn, if smooth, it is quiet, but right when I hit a "bump" while in a turn, it squeaks a lot!
Old May 29, 2007 | 07:45 PM
irish44j's Avatar
retired moderator
sounds like something is loose. Double check to make sure all suspension bolts back there are torqued to spec.
Old May 29, 2007 | 07:48 PM
!PrjctMax!'s Avatar
If something from the shock were to be loose, then wouldn't I feel the car shaking or vibrating at higher speeds? I will definitely check this tomorrow, but that just seems a little odd.
thanks for the info
D Mason
Jun 21, 2016 04:43 AM
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
uttadms31
Sep 30, 2015 05:24 AM
