right front spring loose, bangs around while driving...
like it says, right front spring bangs around and is loose. i can't afford new suspension right now and i don't know what needs to be done. can the spring be turned or tightened in any way??? any help woiuld be appreciated>>> thanks
lol, yeah actually it is dumbass, the strut plate holds that in place as well as the strut. i also have a upper tie rod thats bad as well, so its allowing that spring more movement than it should have. i looked at the receipt from the dealer and did'nt see the upper tie rod on there, and it aint gonna be cheap to replace the front suspension. plates, struts boots and tie rod and struts are gonna kill me in the pocket. anyone know a good online sight for reasonable parts??? any help is appreciated><><>
lol you have an upper tie rod.
your posts keep making less sense.
Once again, you're spring is not loose. The weight of the car compresses the spring, if it wasnt then I doubt you would be driving it. Other things might be loose(strut mounts, ball joints, tie rods, ect..) but not the springs themselves.
I think it is impossible for a spring to move around in our macpherson style suspension.
And we have no upper tie rods, only lower.
first off, grow up dude. i'm not a mechanic and thats what the dealer wrote on the invoice, i'm just trying to figure out what needs to be done first so i don't have a serious issue. instead of typing immature little posts, why don't you use your vast knowledge and put in your 2 cents?? kevlo911 is doing that and thats what i need, not little smartass comments.........
I hope you can fix your loose spring!!!
