squeaky clutch!
Old Jun 4, 2007 | 03:35 PM
Y2k2maxse's Avatar
squeaky clutch!
My clutch tends to squeak a lot, sometimes when engaging, sometimes when disengaging. Is there any simple or quick fix to this? As far as Im aware, I have to replace it. Otherwise it works fine, just an annoyance.
Old Jun 4, 2007 | 04:03 PM
Glude's Avatar
Mines always made a squeaking when I engage or dissengage it, never really had a problem so Il probably just replace when it goes out.
Old Jun 4, 2007 | 06:52 PM
Bezzle01's Avatar
Is it the clutch pedal or coming from under the hood? If its under the hood, theres a rubber piece thats attatched to the tranny on the top front side. pull the rubber piece out and put some grease in there using your finger. Try to use a grease with no detergents and oil based. It will keep it from squeeking again for a long time. If its the pedal itself then you can use the same type of grease or even a silicone based grease in spray or tub form and just rub every joint and moving part down and it should go away. Its worked for me in the past. Good luck.
Old Jun 4, 2007 | 09:53 PM
eK9aT10pSi's Avatar
use white lithium grease, works perfectly! i use that for when i do clutch jobs.
Old Jun 5, 2007 | 12:34 AM
nyhim's Avatar
yea i had this same problem, if you use the grease it would get rid of that annoying sweaky noise.
Old Jun 6, 2007 | 07:40 PM
Y2k2maxse's Avatar
AHH!!!! IT WORKED! lol thanks again guys..that was a HUGE annoyance to me..especially when I have people in the car. stupid dealership told me i needed a new clutch.. i put grease under the dashboard on the moving parts of the clutch..squeak went right away.
Old Aug 13, 2007 | 12:11 PM
Preston Drake's Avatar
I tried to tackle this problem yesterday. Tracked the noise down to that exactly location on the front/top of the gearbox, but couldn't pin the noise down any more precisely than that. Is it:
-inside the hydraulic piston?
-at the ball/socket joint between the end of the pushrod and the clutch fork (just outside that rubber boot)?
-down inside the clutch housing?
I tried hosing down the first two items with Tri-Flow (maybe not the best long-term lube, but it makes troubleshooting easy), but the noise is still there.
I pulled the rubber boot out of place to peer inside the clutch housing, but I'm reluctant to just spray lubricant randomly inside there.
Ideas?
Old Aug 13, 2007 | 12:22 PM
maximadave's Avatar
detailerdaveb@gmail.com
Will this work for the 5.5 gen 6-speeds too? Mine is squeaking as well.
Old Aug 13, 2007 | 02:14 PM
Glude's Avatar
I need to get some lithium grease and try this, mine also does a lil click though so I need to get down there and check that out. Maybe when its not 100+ outside.
Old Sep 8, 2007 | 07:41 AM
tkchan23's Avatar
Same Issue
Same thing in my 5.5 6 Speed? Will this work and how easy is it to fix? Thanks.
Old Sep 8, 2007 | 08:06 AM
Y2k2maxse's Avatar
yes the 5.5 and 6gen trannys are the same (as far as im aware) so it willl work in both cars.
Old Sep 8, 2007 | 06:16 PM
tkchan23's Avatar
any diagrams to figure out what area to grease if noise is coming from under the hood? i've already greased underneath my dash but like others, noise can be heard outside and is quite embarrasing...
Old Sep 9, 2007 | 08:45 AM
Y2k2maxse's Avatar
I have the noise outside also..not terrible tho not very loud. i havent figured out a fix yet..
Old Sep 9, 2007 | 12:42 PM
Bezzle01's Avatar
Yea just pull out the rubber piece and put lube down in there. I wouldn't use a spray lubricant because its very thin and will wear off quicker. Use a thick grease for that area and make sure it has no detergents so it will last longer. Forget the type I used exactly but go to the autoparts store and ask them, they will probably know. I'm sure bearing grease would do the trick. Dont be scurred its just the fork down in there and the slave cylinder. It wont hurt anything.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
