Sponsored by:
Sponsored by: CARiD
Where do I wire VAFC to NX window switch.....??????
Old Jun 10, 2007 | 05:44 PM
i30dvr's Avatar
Ok I have recently installed my vafc and have the 6 wires hooked up from Jime's diagram. For those with the Mevi or OOVI which wires do you tap into for the VI???? I know the pink and orange from the vafc, but where from the window switch????
Old Jun 10, 2007 | 07:27 PM
jmeister's Avatar
Why are you using a VAFC and a RPM switch?
Old Jun 10, 2007 | 11:20 PM
gtr_rider's Avatar
192.168.1.1
http://www.vqpower.com/v2/readarticle.php?article_id=98
Old Jun 12, 2007 | 03:18 AM
i30dvr's Avatar
the rpm switch was installed when i put the motor in the activate the OOVI. Now i want more control so i installed a vafc...
Old Jun 12, 2007 | 07:31 AM
jmeister's Avatar
Original post was misleading since you all ready had Jime's diagram I figured the VAFC was connected. So you ditched the RPM switch? Get everything figured out then?
Old Jun 12, 2007 | 07:56 PM
i30dvr's Avatar
the rpm switch is still wired in w/ the 5000rpm pill....and the wires for the vafc to control that aren't wired in cause i want to find if i can just tap into the wires for the rpm switch or just take it all out
Old Jun 12, 2007 | 08:41 PM
streetzlegend's Avatar
Dude you gotta explain yourself a little better. Do you have a VAFC2 or VAFC1. If you have the vafc2, then completely eliminate the rpm switch and use the vafc.
Old Jun 13, 2007 | 04:21 AM
i30dvr's Avatar
i have a vafc2
Old Jun 13, 2007 | 09:24 AM
Then you dont need the rpm switch at all, sell it to someone. All you gotta do is hook up the vtec wire to the manifold and then ground the other pin. The vtec wire from the VAFC2 provides 12volt unlike the rpm switch (depending which one u have)
Old Jun 17, 2007 | 12:00 PM
i30dvr's Avatar
which pin are u talking about grounding???? the vtec wire isn't long enough to go up through to connect to the manifold.....do i need to extend it????
Old Jun 17, 2007 | 12:08 PM
ofcourse you need to extend it. im talking about the little plug that activates the vias. dont you have the rpm switch hooked up to your 00vi? u should know what im refering too.
litch
123
Jan 4, 2024 07:01 PM
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
