Knock senz0rz
Knock senz0rz
I have a 0702 code and a 0304 code that keep coming up about 100 miles after I reset the CEL. I replaced the o2 sensor in the rear bank for the 0702 code and the same thing happens. I think my knock sensor might have shiiet the bed too, because I tested it (correctly I hope) and I found an open circuit. I kept it unplugged and went for a drive around town and I noticed the car drove the same with the knock sensor unplugged. So should I buy a new knock sensor?
just try to replace your harness as NmexMAX said and get that code erased... and leave ur negative battery terminal unplugged for overnight or something...then if it decides to poop on ya again then u know its time to change that sucka..
Originally Posted by Fr33way™
Isn't the knock sensor known to also trip the o2? Sounds like you may have went backwards to solve the problem.
Im in the same position right now im throwing both an 02 sensor and knock sensor code. i was just gonna replace the o2 sensor first and see what happens. the local auto parts store has them instock and they tell me that they have an OE 02 sensor and a universal one with about a $20 price difference. would the universal be ok or should i get the OE one?
Universal is ok, but your going to have to take the old one off cut the connector and basiccally solder the connecter to the uni one. If you get the OE its all plug and play
Originally Posted by maxima985spd
ok thank you. got the part number by any chance?
Haha prob right. Do what i said earlier w/ reseting the ECU and driving 50 miles before the MIL comes back. Check then to see if the KS is there and that will determine if it is on its own or with the 0702.
DC_Juggernaut
Sep 28, 2015 04:07 PM
ballerchris510
Sep 11, 2015 05:29 PM
