help hurry cant read codes
Old Aug 12, 2007 | 04:54 PM
skweaky's Avatar
my car has been running bad for the past bit. it seems to run worse over longer trips but sometimes it just does it at random. it cuts power like the maf code does and it did throw that code befor. i cleared the code then because the wire was grounded out. i fixewd the wire then reset ecu with a reader. now it is still runing bad and a code reader wont work. it reads error or conection problem like its not even plugged in. i also tried the manual code check and the check engine light would never blink the codes. the cel isnt on and ive tried resetting via unpliugging the battery but still nothing. why cant i check/clear my codes guys?
Old Aug 13, 2007 | 06:21 AM
skweaky's Avatar
nobody knows?
Old Aug 13, 2007 | 06:23 AM
Kevlo911's Avatar
Kevlo for President
Maybe you grounded the wrong wire? RE TRY the ecu screw method, it is quite easy IMO.
Old Aug 15, 2007 | 09:15 PM
skweaky's Avatar
i tried it a few times i didnt just ground the wire. it was separated so i spliced everything back in like stock. it threw a maf code and i cleared it and its just gettin me that i cant check my codes now. did my ecu short out from the wires maybe touching on the maf?
sctludwig
Sep 1, 2022 01:32 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
jchronis2552
Sep 21, 2015 05:52 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Steven Orozco
Sep 12, 2015 10:41 PM
