fans go on @ start up
Old Aug 28, 2001 | 06:49 PM
buss95max's Avatar
in the morning i start up my car, and my fans turn on..sometimes the car will just shut off while its warming up. i looked up "overcooling" in the haynes manual, and it said it can be a faulty temp sensor. can this be causing the problem? also once the temp gauge needle gets half way(normal temp) the problems stop. but if the needle stays a 1/4 of the way high my fans stay on. anyone got any ideas? this only happens if my car has been sitting over a period of time(~4 hrs)
Old Aug 29, 2001 | 05:21 AM
njmaxseltd's Avatar
1) Do you have aotomatic climate control?
2) Is your A/C compressor running?
3) Will the fans come BACK ON when the car gets hot?
Your fans will run anytime your A/C compressor is running. If they are on when the engine is cold and off when it's hot you might have a wire crossed or mixed up. Of for that matter a relay is in the wrong spot. ie - Normally closed relay in a spot that calls for a normally open relay. Have you or anybody else been playing with the electrical system trying to make mods?
Old Aug 29, 2001 | 06:00 PM
buss95max's Avatar
1)nope
2)nope
3)the fans function perfectly once the gets warmed up.
i havent messed with the wiring, and niether has anyone else..
it takes the needle on my temp gauge awhile to hit normal temp. i looked up in the haynes manual and it said its my temp sensor... ANYONE GOT ANY IDEAS???? DANIEL B???
Smackasmith
Feb 1, 2016 12:40 AM
RWCreative
Sep 21, 2015 11:01 AM
QueensMAX
Sep 15, 2015 04:14 AM
asianstyle
Sep 10, 2015 11:30 AM
trungg86
Sep 4, 2015 04:58 AM
