2K2 Alarm Fix WRITE UP is done.
Old Oct 13, 2001 | 08:23 PM
BigDogJonx's Avatar
Well here it is for you folks out there that needed it. I made it AS DETAILED for you people that are not too "electronical." If you have any questions, email me.
http://www.nrrrd.net/dixit/alarmfix.html
ICE and 2MaxGuy, Let me know if I am incorrect in the writeup. I dont know much about relay's, but I made it as fool proof as possible.
Dixit
Old Oct 13, 2001 | 09:21 PM
TimW's Avatar
The silent but deadly Moderator
nice...
very detailed...
one question.. if that tap works loose, the HIDs quit right?
btw.. I just went for ride.. sweeeeeet!! I used alittle of both your writeups.. couldnt/wouldnt have done it w/o you guys. thanks again...
Old Oct 13, 2001 | 09:23 PM
BigDogJonx's Avatar
Re: nice...
Originally posted by TimW
very detailed...
Believe me when I say THAT TAP aint coming loose. They are very tight, and on top of that, it has a safety clip. On top of that it slit the wires and it is in there tight. I also TAPED it with Black wire tap to make it look more OEM, since the BLUE was really visible.
Check you PM by the way........
Old Oct 13, 2001 | 09:31 PM
2maxguy's Avatar
Re: 2K2 Alarm Fix WRITE UP is done.
Dixit
Looks good. I put some general information on relays for anyone in need of detailed information.
http://www.cardomain.com/member_page...page_id=158868
Old Oct 13, 2001 | 09:33 PM
BigDogJonx's Avatar
Re: Re: 2K2 Alarm Fix WRITE UP is done.
2MaxGuy, what kinda relay did i Use, I forget what it is called, SPST SPDT? I dont that part of relays at all.
And by the way, the link aint working.
Old Oct 13, 2001 | 09:34 PM
2maxguy's Avatar
[QUOTE]Originally posted by 2maxguy
[B]
Try this link instead.
http://maxima.cardomain.com/member_p...=158868&page=5
Old Oct 13, 2001 | 09:38 PM
2maxguy's Avatar
Re: Re: Re: 2K2 Alarm Fix WRITE UP is done.
If it has 4 tabs on it then it's SPST (single pole single throw). It has one NO (normally open) contact which closes when power is supplied to coil.
5 tabs, SPDT (double throw) there is a NC (Normally closed) contact included.
Old Oct 13, 2001 | 09:43 PM
BigDogJonx's Avatar
Son of a........ Where did you make those Wiring diagrams from? Do you use a special program? Man.............. That is some good stuff.
Well that page really helps me understand how it really works now, the relay that is.
Old Oct 13, 2001 | 09:46 PM
2maxguy's Avatar
Re: Re: Re: Re: 2K2 Alarm Fix WRITE UP is done.
Paintbrush! Comes on almost every computer.
Ray
Old Oct 13, 2001 | 09:48 PM
BigDogJonx's Avatar
Re: Re: Re: Re: Re: 2K2 Alarm Fix WRITE UP is done.
Ray
But I mean the HID wiring schematic you got on page 4, that is not that easy to do with Paintbrush. Very hard. Would be alot easier if you had a program like VISIO, where you just drop the icons and then make lines.
Dixit
Old Oct 15, 2001 | 12:08 PM
myktek's Avatar
Re: Re: Re: Re: Re: Re: 2K2 Alarm Fix WRITE UP is done.
First of all, i'll like to thank all they guys that put all there time in putting up all this info on the 2K2 conversion, thanks alot guys.
ok, my question is to 2maxguy, Is your setup like ICEY2K1's where when u turn your high beams on, the lows stay on too? or is it like BigdogJonx's where I think that the low's turn off. or did he fix that already, sorry about the stupid question.
Old Oct 15, 2001 | 12:21 PM
Colonel's Avatar
Old Fuddy Duddy
Re: Re: Re: Re: Re: Re: Re: 2K2 Alarm Fix WRITE UP is done.
Nope both writeups allow for the HID to stay lit while the HB are on.
TallTom
57
Oct 14, 2025 05:16 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
