It's official - N/A 3L cracks 12's
It's official - N/A 3L cracks 12's **video added**
Edit: for the video click here.
Set some new PB's yesterday at the track. The "little" old 3L went 12.83 @ 106.90 mph. On another pass it trapped 108.26 mph (on a 12.90 ET).
Scary thing is, there's a few tenths left in it yet. The car's only roughly tuned and I had a lot of problems with it breaking up at high rpms due to sudden lean-out. I'm lucky these are tolerant engines and I'm N/A or the motor would have blown. Thankfully I had the knock sensor working overtime. It was unexpected, the night before I wasn't seeing that as much doing some street tuning, thought it was safely rich so I need to look into it, might be a fuel pump/supply issue or it could be the stock ECU switching tables on me again (don't even ask how many problems the stupid Nissan ECU has caused me). Also, my launches and shifts were a bit rusty shall we say, not having raced in a year... that plus a shifter **** that's stripped and comes right off the shaft - so mostly pulling 1.8x sixty foots, worse than the mid 1.7's I'm used to. I think I'm going to change my launch technique a bit with this setup now too, it needs to be launched a bit higher than last year's.
Considering all the factors, I'm thinking this car should be able to do 12.6x and trap 109. I never had 1 solid pass all day yesterday. Even the 12.83 and 12.90 were glitchy. Others were worse; for example the car crapping out up top turned a half-decent start on a 1.79 sixty foot into a 13.05 @ 94.57, and on another run it turned a 1.88 sixty foot into a 13.19 @ 88.77. (
at the trap speed)
Anyhoo, timeslip is below, and I have video footage which I'm just editing together and will post soon.
at the trap speed)Anyhoo, timeslip is below, and I have video footage which I'm just editing together and will post soon.
Fantastic job, Dandy! And no wisecracks about how Canadian air is actually 20% nitrous.
Say, would you like a heads-up when PINKS does their next show for All-Out racing? You would really shake up Rich with a mid-12's 4-door Maxima!
Seriously - you have done a fantastic job on that new engine. Congrats.
Wow man thats insane!!!! I have your twin car expect its over a second slower LOL. KT3 98 SE FTW!!! heh. way to represent for the VQ30, maybe people will think twice about just going to the 3.5
Yeah it looked squished. I loved the editing BTW. It definalty needs to be on youtube so everybody can see what are cars can do.
I'll put the vid up on Streetfire and YouTube once I fix it.
wow, dyno time...we to justify those times...lol
and estimate weight if possible...you keep pushing the boundaries dandy, just when everyone probably though a 3.0L N/A would never break into 12's...it's amazing we can run such good times for a FF car with not that much power to be honest compared to many other cars around the same weight that run low 13's and never faster with a whole lot more power...ie. evo's and sti's (no traction excuses there)...so I guess how and when the power is made is crucial...
we need some inside video one of these days to hear what it sound like in cabin...!
OK I fixed the video I think... same link up top in the first post but different file.
To all who asked about a mod list, it's been updated in my sig.
Same as last year, actually a little heavier, I left the rear seats in this time. Check the timeslip database.
M&H 24.5x8.5x15
Once I have it tuned up properly, 8200 most likely.
Freedom from 13's - hah. So you liked the music or you didn't?
I've thought of it, just haven't had time to rig up some kind of mount system, but I plan on doing it at some point. I think I'm also going to try some new angles from behind the starting line looking down the track from a tower view etc.
M&H 24.5x8.5x15
if you still have the passenger seat in the car, I use this:
http://www.soloperformance.com/Shopp...0/Default.aspx
works with all cameras and is very adjustable and steady...!
the vid is the proper aspect ratio now. also I liked the music, sounded very epic which is fitting because it's an epic milestone.
btw did you have a problem on the 1-2 shift? it sounded slower than normal.
oh i see, yeah it definitely has more in it. i didn't want to say it before you confirmed, but that shift sounded pretty brutal, I bet you're giving up almost a tenth right there. i know when I shift 1-2, you cant even tell that I've shifted except for the wheelspin and change in engine tone, I suspect yours are the same way normally.
