Slow Timing
Old Oct 4, 2007 | 06:26 AM
Wheelie King's Avatar
Slow Timing
Standard timing for my 5th gen is set at 14 degrees. I checked mine and it was down around 10 degrees. I bumped it to 12 and have not had a chance to check it again since then. I can probably get ahold of a used ECU. Does anybody know whether swapping the ECU might help?
Old Oct 4, 2007 | 06:30 AM
NmexMAX's Avatar
dot dot dot ...
Do WOT run and see what it (curve) looks like.
Old Oct 4, 2007 | 11:40 AM
Are you talking about dynoing it? I did it today but I'm not sure what the results say about timing issues. Max HP was about 190 at 5.5k rpms. Curve was not very steep. I'll try to post it.
Old Oct 4, 2007 | 12:57 PM
NmexMAX's Avatar
dot dot dot ...
No, I mentioned nothing of dynoing. Use the logger, and log (record timing advance in *) a run through the RPM's. Then post the #'s. If you put down 190, I wouldn't be worried about it. But I would be concerned that peak is @ 5500.
Old Oct 4, 2007 | 01:11 PM
maxkid123's Avatar
what would cause the timing to drop like that???
Old Oct 4, 2007 | 01:15 PM
NmexMAX's Avatar
dot dot dot ...
Mine is @ 12 sometimes @ idle in gear, but @ 17 or so in P/N. (for reference values, readings should be taken in P/N, via FSM)
mvm062
Nov 30, 2020 09:00 AM
intimidator
Sep 5, 2015 07:23 PM
305head
Aug 26, 2015 09:03 PM
yat70458
Aug 3, 2015 01:16 PM
