NISSAN TIRE JACK-TIRE ROTATION????
Old Oct 21, 2007 | 07:07 AM
paulpearl's Avatar
Is it possible to rotate my tires with only using the oem tire jack provided with my 01?? I have taken my wheels off before when painting the calipers but did this one wheel at a time..I know the recommended jack location is right near each tire on the frame lip but I was wondering if I jack it up in the middle where the front/rear doors meet on the frame will this hurt the car or has anyone done this???? I have a new torque wrench and want to try it out......
Old Oct 21, 2007 | 05:54 PM
Maxgig's Avatar
I used the oem jack for that exact reason before I bought stands. I used the front jack point and managed to get the rear tire off the ground just enough (about 1/2 inch or so) to be able to slide the tire off. Incidentally, I use that method every year when it's time to put the winter tires on the Volvo, but it has a much studier jack and the lift point is a lot closer to the center of the car than on the Maxima.
MatthewsMaxima
Sep 11, 2015 03:21 AM
NissLover
Aug 22, 2015 10:26 AM
gizzsdad
Aug 19, 2015 01:01 PM
Maxgig
Aug 18, 2015 09:17 PM
District
Aug 15, 2015 08:23 PM
