quick help..dome lights
Old Nov 30, 2007 | 12:43 PM
blackmax07's Avatar
how do i remove the plastic, so that i can replace my bulbs..i was messing around with it, but I don't want to just snap it and then have to replace that also..thanks, i have an 07.
Old Nov 30, 2007 | 01:09 PM
redls1's Avatar
MAXIN' ON
I was gonna try doing it and after tugging a little pulled a little to hard. The whole console I believe it held in place with plastic push plugs. If I kept on tugging I would have to resest the plugs and then pop back in place but never got that far. Let me know what you find out, Ill check the fsm if I have time later.
Old Nov 30, 2007 | 01:18 PM
blackmax07's Avatar
from what i know its simple, just supposed to crow out the plastic top..hmm not sure..someone help me ha
Old Nov 30, 2007 | 02:41 PM
07 Graymax's Avatar
i replaced my bulbs using small flathead screwdriver inserted at top of lens gently but easely done
Old Nov 30, 2007 | 02:59 PM
blackmax07's Avatar
alright so now that i know the lens can come out, let me go try this again..hopefully the thing doesn't snap in 2..
Old Nov 30, 2007 | 03:22 PM
blackmax07's Avatar
i got it out..but the damn bulb is like so hard to get..im pulling but its not coming out wtf.
Old Nov 30, 2007 | 04:03 PM
blackmax07's Avatar
Alright all done, here is the guide for anyone wondering.
Some screw drivers like these will do just fine.
Use those two, to basically pry out the plastic clips..don't worry it wont break, the plastic is tough..
Once thats removed, you wont have enough room to get the bulb..There is this metal piece that reflects light, it comes right out..basically pry it out from the sides..don't worry it wont break, its meant to pop in and out..
Once all thats out, grab the bulb and pull..it takes effort, and basically use common sense and reverse order..
Old Nov 30, 2007 | 04:20 PM
redls1's Avatar
MAXIN' ON
What bulbs did you replace them with?
Old Nov 30, 2007 | 04:22 PM
blackmax07's Avatar
194 6 led white.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
maximusrising
Sep 2, 2015 09:55 AM
