How to reprogram a new fob?
Old Dec 24, 2007 | 11:32 AM
heynow's Avatar
I just got a new fob, and i'd like to reprogram my keyless entry to work with the new remote. I remeber seeing the procedure in the sticky's somewhere, but now i can't find it .
I found something on nicoclub:
1.Get in & lock the doors
2.Insert the key into the ignition 6 times within 15 seconds
3.Hazard lights should flash
4.Put key back into the ignition & turn to Accessory
5.Press the master door lock (on drivers door arm rest) unlock/lock
6.Hit the lock button on the remote
7.Hazards should flash
8.Pull key out and open the drivers door and then close it
9.It should be set
Is this the right procedure?
Old Dec 24, 2007 | 11:38 AM
NmexMAX's Avatar
dot dot dot ...
Old Dec 24, 2007 | 12:01 PM
Digitized's Avatar
***ding ding ding! you are correct sir!
Old Dec 24, 2007 | 03:52 PM
adriena's Avatar
sounds right to me
Old Dec 24, 2007 | 03:55 PM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showpost.ph...9&postcount=15
Fbana41
Aug 29, 2016 12:18 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
jerrod99_se-l
Sep 19, 2015 06:54 AM
mix master
Sep 7, 2015 08:28 PM
intimidator
Sep 5, 2015 07:23 PM
