rwd vq35 valve covers
i got a free vq35 from a 2005 g35 6spd from work and i was wondering if the rwd vq35 valve covers can be used on the fwd vq35. they are the updated ones, and i believe my rear one is leaking. i assume the drivers side cover cant be used because the oil filler neck is too high, but what about the rear one?
In any case, we know that it'll bolt up since RWD/FWD heads are the same. The only difference is probably where on the cover the PCV valve is located. Perhaps also whether or not the #1 coil is secured at an angle.
Because I saw some "painted" covers over on www.350z.com and was curious. I have better things to spend my money on right now, but maybe a little "bling" in the future.
the fronts would be pointless to put in since they have an "extended" oil fill to clear the 350z intake manifold... rears might fit as mentioned as long as the coils are in the same positions as the fwd's
____
You've got a nice little mod list in your sig
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
Not bad!
