ABOUT TO DO MY LW FLYWHEEL/CLUTCH
Well I got my fidanza flywheel and F1 clutch in the mail the other day. I'm waiting for my friend to hook me up with some royal purple for the trans. I got a new rear main seal. I've heard its a good idea to replace the axle seals while the trans is out but i'm not going to worry about it. i'm taking a day and a half to get it done so i think i should have plenty of time.
Any hints/suggestions?
Oh god, your about to make the EXACT SAME two huge mistakes that I myself made 2 years ago.............
1: that gripforce f1 clutch will ruin your fidanza, and you'll have to buy new inserts.......
2: If you attempt to do the rear-main seal without removing the upper oil-pan it WILL leak worse than before....... FSM procedure FTMFW.
Seriously, get your money back somehow & do it right, or else it's going to cost you much more in the long run. The rear-main seal on a maxi pretty much never leaks, but the upper oil pan end seal does! And that's the one you'll be improperly stuffing in if you try to just change the rear main. I'm not alone on the 'it leaked worse than before' either. But I think I am the only one stupid enough to give that gripforce F1 a try and have it ruin my fidanza.
damn that sucks about the f1... thats the only clutch i can afford right now and i need a new one. maybe i should get a 5.5 gen 3.5l clutch? will it fit? i suppose i'll get the axle seals and how do i seal the upper oil pan gasket? i have some GMS engine sealer at the house, should i just drop the pan enough to squirt some in or what? that means i'll have to change my oil again which sucks since i just did it last week..... lol
thanks for that help!
The pan seal is complicated, it's for the upper pan, not the lower, which means if you want to do it with the tranny out = engine hoist = pita. Also, you have to get about $70 worth of parts from the dealer. Permetex grey is equivelant to what nissan uses for gasketmaker. Honestly, you shouldn't have to worry, it has to leak REALLY REALLY bad for it to get on the clutch, most of the time I just re-tourqe the two long upper oil pan bolts at the back to 15 ft/lb's, they loosen up due to their length, which is probably why the VQ likes to start sweating oil inside that bellhousing after 50k, but again, it has to leak REAL bad, I've only seen 2 rear upper oil pan seals leak bad enough to warrant replacement, and even than they didn't get on the clutch (one of them was mine when it was dripping almost constant once warmed up)
awesome thanks a lot! i just looked on ebay and they have an exedy 5.5 gen clutch for 186+ shipping... unless you know how to get them cheaper thats probably what i'll go with. the clutches are really compatible??
well i'm picking up the axle seals and trans pos sensor friday. i talked to Gripforce and they told me i wouldn't have any problems with the f1 clutch and fidanza flywheel. i'll be using royal purple in the trans. so hopefully this weekend it will be done
Or pick up an AE clutch exedy :chuckles:
http://kevlo911.ic3donline.com/image...p/IMG_1689.jpg
Call the dealer/DAVEB
^^No different than what I get for $120 shipped in the link I put above, but HUGE
that he should get that.
Oh, I must be wrong than, yeah, you won't have any problems for sure, I mean they wouldn't say that just to sell a clutch of course.
that he should get that. Oh, I must be wrong than, yeah, you won't have any problems for sure, I mean they wouldn't say that just to sell a clutch of course.
well he assured me i wouldn't have any problems and that they sell that combination all the time.
what was it about the f1 that would ruin the fidanza?? you said it would ruin it but what exactly happened to make you say that?
Crusher103
41
Sep 27, 2011 05:40 AM
dnice02
Aug 13, 2011 07:23 PM
Dave B
Jan 29, 2004 03:09 PM
