can fed car cat fit on/in cali car
Old Feb 9, 2008 | 04:32 PM
Snypa's Avatar
i think my cat went bad and im about to buy one from an org member. He has a 99 5 speed and so do i. The only difference i think is his car is fed spec while mine's cali spec. Will this cat still fit.? what do you guys recommend?
Old Feb 9, 2008 | 04:34 PM
MAXSE5SPD's Avatar
cats should be the same. the front exhuast tube is a different story.
Old Feb 9, 2008 | 08:53 PM
99BlackMaxMS's Avatar
Yes they will work, the exhausts are the same after the y pipe.
Old Feb 9, 2008 | 10:32 PM
Snypa's Avatar
ok.sounds good.are thy all welded on or do some come with bolts? i think im still on stock which i think would mean its bolted....so wouldnt wanna do any welding there, but instead get a new one tht can be bolted on.
Old Feb 9, 2008 | 10:57 PM
pmohr's Avatar
No more Maximas...
What do you mean? All of the stock exhausts have the cat bolted between the Y and the B.
Old Feb 10, 2008 | 04:30 PM
Snypa's Avatar
Well the reason i asked was that i was looking into getting a new cat from this guy.however he said he would have to cut it off and that its a universal cat.so i asked him why he has to cut it off, he said it was welded on.
Old Feb 10, 2008 | 04:38 PM
pmohr's Avatar
No more Maximas...
Well in his case with the universal, it makes sense.
Otherwise though, on (most) any OE replacement cat there'll be flanges and it'll be bolted between the Y and B.
Old Feb 11, 2008 | 12:27 PM
Snypa's Avatar
ohh,ok.well...i guess ibtter leave it alone.i can be sure mine is bolted on,....not planning to weld anything on under there.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
stromm
Aug 27, 2015 04:13 PM
carguy96
29
Aug 21, 2015 02:43 PM
1992maximase30
Aug 5, 2015 09:27 PM
