What's it called, and where do I get it?
Old Feb 22, 2008 | 08:52 AM
Deckdout2's Avatar
Play with my balls
I think it's made by Metra, I'm actually 80% sure it is. It's for the dash or any type of fab work, comes in a flat square piece and you can cut it to fill in gaps around the headunit and such where the hu trim just doesn't fit/work. I can't think of the proper terminology for the life of me, and I've search but can't find it again. (found it once, but lost the link) O, and it's got a grid on the back to make straight cuts, not sure how big the whole piece is but 1 should do the trick. Any help here? Links would be great too.
Thanks guys.
Old Feb 22, 2008 | 09:04 AM
BLACKonBLACK98's Avatar
Former Vendor
metra abs gridplate. i googled it and this was the cheapest i found:
http://www.priceinsanity.com/servlet...30-12-x/Detail
*edit* you can find regular abs sheets a lot cheaper, unless you really need the grid.
Old Feb 22, 2008 | 09:55 AM
Deckdout2's Avatar
Play with my balls
Sweet, perfect, and thanks! That's exactly it, and what I was looking for. I don't really need the grid, I can make straight cuts, but now I know what term to look for. Thanks again.
Old Feb 22, 2008 | 01:05 PM
Deckdout2's Avatar
Play with my balls
ordered!
Old Feb 22, 2008 | 01:11 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Ummm Paramy ..what do ya need it for?
AND ...I coulda just sent a sheet with your other stuffs.
Old Feb 22, 2008 | 02:45 PM
nismos14's Avatar
§è~® f®ÈÄk
Pwnt.
Old Feb 22, 2008 | 03:37 PM
mendon99's Avatar
tastey wheat
lolercaust
Old Feb 22, 2008 | 07:17 PM
Deckdout2's Avatar
Play with my balls
Damnit. Actually, I'm possibly going another route with the AVN6610 and might not use the GXE kit. Just something to play with and see how it turns out. Also, I need a little bit for fabricating on some other installs that I do, so I needed to pick it up anyway, but didn't even think to ask ya. till next time I need some more.
Old Feb 22, 2008 | 07:39 PM
Pearl96Max's Avatar
Ahhh so for the double din area coverage? You know the AVN already comes with a precut flexible sheet right?
Old Feb 22, 2008 | 11:41 PM
Deckdout2's Avatar
Play with my balls
Yes for that area. My idea is to recess the AVN a little. I didn't realize it did come with it. The sheet it comes with would need to be wide and tall enough to extend the width of the opening. I'll play with it to see if my idea would work.
Old Feb 23, 2008 | 09:16 AM
Pearl96Max's Avatar
It is, Ill see if I can get one out to you ..
Old Feb 23, 2008 | 09:23 AM
Deckdout2's Avatar
Play with my balls
Your hospitality is appreciated.
Mar 12, 2020 12:06 AM
D Mason
Jun 21, 2016 04:43 AM
bigfrank
Oct 1, 2015 12:51 PM
maxima297
Sep 24, 2015 08:57 PM
jfl330
Sep 4, 2015 01:44 PM
