How to change a radiator?(didn't find it in the stickies)
Hey, guys, I went through the stickies, but no luck. I would like some help(information wise) on how to change the radiator-mine is leaking. Any help is greatly appreciated. Thank you.
Dima
Dima
I think thats the weasy one of all . Unbolt pull out and your done lol. Really drain it first then there are 2 hoses. Look around and you can find the brackets that hold the radiator they are right on top and lift out. You can take it out with the fans on it just unplug them.
drain the coolant, there will be 4 lines on the radiator if the car is an automatic, 2 big ones for coolant and 2 small ones for the tranny. Take the cooling fans out with the radiator and put them on the new radiator before you put it back in the car. You dont have to but it makes things easier. Then fill the radiator and run it for a bit. Keep an eye on the coolant level low because there will probabley be a bit of air in the cooling system.
I just did the replacement, not hard at all. Here's my summary:
http://forums.maxima.org/showthread.php?t=554263
I was just looking at the radiator in my 95 maxima (which is getting replaced soon as it is leaking) and noticed there is a radiator in front of the radiator. Is that not a tranny cooler? I have an automatic transmission by the way.
that is the ac condenser my friend
MatthewsMaxima
Sep 11, 2015 03:21 AM
kirkhilles
Aug 8, 2015 10:53 AM
RealityCheck
Aug 5, 2015 06:18 AM
