What Is The Correct Torque For Fuel Injection Hose Clamps?
How about inch-pounds? Or how about just tighten them until the hose can't rotate anymore! If your rubber is squeezing thru the band, then you probably need to replace your hoses (soft)! Are you gonna need the torque values for the bumper signal light screws next?
Actually, would you happen to have the torque value for my key in the ignition? In Inch-lb?
Really? No need to have the car running? I'm pretty sure I see it leaking after it has started. I notice in the manual it says in the last step of installing the injectors to test for leaks - but I don't see how this is possible without closing everything up and re-connecting everything.
anyhow the fuel pump WILL run and the line WILL pressurize just by putting everything together and turning the key to ON. it'll do that for like 10 seconds then shut off. no need to actually crank it.
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
