Trunk will not open
Trunk will not open
I did a trunk swap on my 95 to a 97-99 about a month ago. I changed the latch on the trunk from my 95 trunk to make it fit. Today my trunk wouldnt open. I can hear it clicking, but not opening. I need to get in there! how can I open it?
take out the rear seat then the pannel in the way it's like a couple screws then find the latch or wire what ever is eposed and open it from there.
or if you know for sure that it is un latching then just pull it hard and see if it doesnt open other wise just take out the back seat like I said.
the bottom of the back seat has 2 hooks you need to pull to un latch the coushon
good luck
good luck
good luck
good luck
Mine wouldn't close yesterday.
Should we blame trunk monkeys?
I normally have to push the button once, pull up, then push again to open mine since the dynamat weighs it down and causes it to stick.
Should we blame trunk monkeys?I normally have to push the button once, pull up, then push again to open mine since the dynamat weighs it down and causes it to stick.
how did you get you fingers in the bottom of where the trunk connects? did you take out your rear seat?
this is weird mine just all the sudden wouldn't open either i could here it clicking but nothing was happening.. tried pulling it from the bottom tried the key.. finally i just turned the key as hard as i could without breaking it and it opened.. i think sad from the beach and a bunch of dust got in there and jamed it up.. took some WD40 to it a couple times and haven't had a problem since..
I had a similar problem, didn't feel like removing rear seats. Took a skinny plastic proom and with the end plastic tip wiggled the latch through the arm rest hole. Usually our cars have a mandatory manual release in the trunk right? I hit that latch and pulled up on the trunk..and it opened
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
