Why won't a 4AT from an '02 work with my '00?
Old Dec 13, 2008 | 09:08 AM
sixteenXnine's Avatar
Title says it all. I posted a thread in FS/FT lookig for a 4AT and someone has a tranny from an '02 maxima.
Why won't this work with my '00 GXE?
What would I have to change?
Old Dec 13, 2008 | 02:37 PM
CMax03's Avatar
traction control and maybe the differential is different requiring 02-03 drivshafts? My quess.....
Old Dec 13, 2008 | 04:56 PM
pmohr's Avatar
No more Maximas...
Valve body electronics are different, I believe. Also the internals should be beefier, to deal with the VQ35. Those two differences are why it was labeled the RE4F04B, IIRC.
I see a lot of the parts are identical. The diff is identical, so axles would interchange. The solenoid pack has a different PN, so check out AT/EC/EL for the wiring to see if they're interchangable.
Other than that, it'll bolt on and your current axles would work. Not sure if it uses a VSS or not, though.
Old Dec 14, 2008 | 01:31 AM
VSS?
Old Dec 14, 2008 | 01:33 AM
pmohr's Avatar
No more Maximas...
Originally Posted by sixteenXnine
VSS?
Vehicle Speed Sensor.
Old Dec 14, 2008 | 05:08 AM
Hm, ok. Driveshafts are the same.... speed sensors are different though. I'm hoping I could wire the '02 units to the '00 TCU without too much difficulty...
The control solenoids are the same as well.
...and rebuild kits appear to be the same....
I'm gonna delve into my Haynes book for a while, and then I'll consult the FSM's.
Maybe with just a couple mods I might be able to put the '02 4at in my '00... (maybe?)
Btheman80
May 1, 2018 04:03 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
BobMax
Aug 15, 2015 12:35 PM
Team STILLEN
Aug 10, 2015 04:29 PM
kenc15
Aug 5, 2015 08:29 AM
