Can't Find Keyless Remote Instructions
Old Dec 14, 2008 | 09:53 AM
GREENlight's Avatar
I know, check the stickies. I've been through them for almost an hour and I can't seem to find them. Maybe I overlooked it somehow, but I'm looking for the instructions. Please HELP
Old Dec 14, 2008 | 02:10 PM
Coolsaber57's Avatar
From the stickies:
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
Old Dec 14, 2008 | 03:08 PM
Snypa's Avatar
takes just a lil search.
Old Dec 14, 2008 | 04:33 PM
snowboi1289's Avatar
I dont know if I read it wrong, but the other keyless remote tut. did not work, I tried it for hours. I'll try this one now. I think I know why its not working for me, I have a different key, not the same as the original Nssan maxima key, its from a hardware store. Its doesnt fit the the ignition all the way, so I have to jiggle it sometimes to make the car start.
Old Dec 14, 2008 | 05:53 PM
bow94z's Avatar
make sure you have the keyless module in your car, loccated by the jack in the trunk
Old Dec 14, 2008 | 07:32 PM
GREENlight's Avatar
Thanks! I'll try it out.
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
