How do I get lateral link out of the LCA?
Plan A: Put lateral link in a vice, twist LCA and pull at the same time.
Plan B: Torch out the runner bushing holding the link in the arm. Then all that's left is the metal bushing on the link. Gently cut that off with a cut off wheel/grinder/sawz-all.
Update
Thanks for the advice guys.. I ended up torching the bushing out and then taking a die grinder to the sleeve. I nicked the link up a bit while cutting the sleeve, but I think it'll still hold fine. Talk about some rust after 160k miles though - no way that thing was coming out with a vice and hammer. The passenger side slid right out thanks to whatever fluid was leaking on it to prevent rust build-up and ultimately destroying the bushing. Hopefully it was either the camshaft sensor or oil pressure sending unit that was leaking as I fixed it, but now it seems like the power steering fluid might be seeping out slowly.
So 2 days later, and 2 new LCAs, sway bar links, KYB struts/shocks and it handles like new again!
BTW, noticed my inner tie rod boot was torn on the driver's side... do I need to worry about this? I really don't feel like messing with my car again anytime soon.
Yeah did that while I was working on the LCAs, but there's no play. Just wondering If I need to worry about the crack in the driver's side inner tie-rod boot. I'm not sure what it's protecting, but I'm pretty sure it's not some sort of greased joint. I'm thinking it might just be like the piston for a strut/shock where the boot doesn't do too much (except break after 10k miles)..
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
