What is causing this squeeling noise? [in the engine]
Old Mar 29, 2009 | 02:37 PM
gladiator's Avatar
I uploaded some vids. Not sure if its the belts thats causing it or what. It doesn't sound like belts because it would squeak like that throughout, no matter if the car is warm or cold.
http://www.youtube.com/watch?v=RuGlJiC3eNE
http://www.youtube.com/watch?v=f3X30hbdd_0
thanks everyone
Old Mar 29, 2009 | 02:43 PM
kringle03's Avatar
Have you done anything to eliminate the belts as a possibility? Better yet do you know they last time they were replaced?
Old Mar 29, 2009 | 02:53 PM
gladiator's Avatar
yeah. everything besides timing have been changed in 05. Previous owner gave me the receipts.
Old Mar 29, 2009 | 02:54 PM
importcf's Avatar
it only squeeks at idle? it could be a belt or pulley ide remove the belt and try to spin the pulleys that u can
Old Mar 29, 2009 | 03:55 PM
Greeny's Avatar
¯\(°_o)/¯
You might have a bad bearing on your a/c belt tensioner pulley, remove the a/c belt, see if the noise goes away, if not, continue removing each set of accessory belts until you find the issue.
Old Mar 29, 2009 | 05:06 PM
Might be a pulley. I know 1 of mine was loose, tightened it up, no more squeal.
Old Mar 31, 2009 | 08:08 PM
maxinout93's Avatar
I had that issue last year on a hot day, One of my belts were squeaking so loudly. I sprayed some belt dressing on the belts and found it was coming from the a/c belt. So I just replaced it since it hadn't been replaced before, put the new belt on, and no more squeak. First I took it to a mechanic, who told me that it was the idler pulley, but I already knew what it was. Also, sometimes the belts can be loose and squeal like that.
Old Apr 1, 2009 | 12:06 AM
burhan92SE's Avatar
drop some tranny fluid drops on each belt one by one and see if it goes away....if it does then its a belt....if not then wat greeny said... ( most likely its belt )
Old Apr 1, 2009 | 11:26 AM
gladiator's Avatar
ATF won't hurt the belt or cause it to slip right?
Old Apr 1, 2009 | 09:17 PM
kringle03's Avatar
Alcohol, Tobacco, and Firearms? Yeah they'd prolly do a number on the belts... but seriously the ATF would just be a diagnostic, if it takes care of the noise you're going to replace the belts anyway, at least I would hope so.
Old Apr 1, 2009 | 10:24 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
would the ATF cause them to slip, but do so quietly? or would it make them grip better? I'm weary of this method when the far superior method is just taking them off one at a time until the noise goes away.
Old Apr 1, 2009 | 11:17 PM
Infam0usMax's Avatar
I was getting the samething and it was water from the water pump gettin on the belts so yeah make sure that your belts dont have water or anything on them and while ur at it check to see if they are old and if u gonna take them off to check dont even put them back on just replace them i just spent $600 on parts for mi engine and waterpump and im still not done so ur gonna have more problems...
Old Apr 1, 2009 | 11:20 PM
gladiator's Avatar
All the accessory belts are new from 05, I have the receipts from the previous owner. Just the timing belt was not changed.
Old Apr 2, 2009 | 05:41 AM
kringle03's Avatar
Um yeah the last time I checked... it's '09 man... You should replace them just due to age...
Old Apr 2, 2009 | 05:50 AM
Greeny's Avatar
¯\(°_o)/¯
Blah, their is no reason to replace 4 year old belts unless there are signs of wear, like cracks or fraying..
Old Apr 2, 2009 | 06:10 AM
LvR's Avatar
LvR
Dude - you have the car there - open the hood and listen at the various rotating members around the belts and get busy with tools. Getting to a funky bearing/pulley is really as easy as that.
As Greeny said already - its prob the tensioner on one of the belts - thats all your videos can make us say.
4 days worth of posts here to find a frigging squeal is ridiculous.
Old Apr 2, 2009 | 06:19 AM
kringle03's Avatar
lol... I'm usually putting between 40-60K on my car per year so not having new belts on almost a yearly basis is like not changin your boxers to me
Old Apr 2, 2009 | 10:04 AM
gladiator's Avatar
Right, what I mean is theres no cracks or wear and the belts look brand new. The owner only put 20k since 05. I don't know how to remove the belts myself, it might be easy for you but not for me.
Old Apr 2, 2009 | 10:15 AM
LvR's Avatar
LvR
OK fine.
What is it you want from this thread then? - a recipe on how to remove the belts or the directions to the nearest mechanic?.
captchaos
Mar 15, 2016 12:18 PM
97_GXE
Sep 15, 2015 06:47 AM
ballerchris510
Sep 10, 2015 09:35 PM
jfl330
Sep 4, 2015 01:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
