High Temp Paint didn't Do Crap for My VG Muffler Assy
By the way guys, I was inspecting my fully painted exhaust system the other day from back in the summer, from 1 salty winter, and it's already rusting on the flanges and the weld spots. It's not rusting through, but I thought from 3 coats of the high temp paint, it could create a barrier to the corrossion.
As far as I know the Maxima's in Canada had Bosal Exhaust systems as OEM...but what I don't get is how the original lasted nearly 16 yrs.
sure it's possible,but not worth it IMO, you wouldn't be able to spray all the way into the pipe, you would probably want to do it after bending the pipes but i don't think it's too realistic of a plan. just go w/ stainless pipes and protective paint on the outside and it'll last as long as you need it to.
Pics soon - just waiting for the injector and the rest of the suspension parts. I'm pretty much ready to go for all the repairs...waiting on a few other items - die grinder cut off wheel in case I need to cut off some bolts, wire cup abrasive, mandrel, some odds and ends. I'll take a photo of all the parts before they go in too. Oh shoot - I forgot to order some drill bits...better do that now.
I sprayed some 1200*F duplicolor on a header to see how long it would last...I thought it would last about 10 minutes and it stayed on the header until I removed it and sent it in to be ceramic coated (roughly 6 months!!!!). So I'll try that on my custom ypipe first just out of curiousity and if it starts peeling I'll ceramic coat it like all the rest of my exhaust headers
Just got back in from spraying the under-body with car wash soap and rinse, to get all the winter road salt off. I'm amazed at how well the grease stood up to the salt, even though in the fall I used the cheapest grease I could get. I pretty much greased any exposed metal by hand AFTER first spraying with used engine oil. The exhaust flanges are rusty but like you guys said, you can't prevent it if it isn't stainless. The Rustoleum High Temp spray paint stood up, and didn't flake off.
So what I found was, the Quaker State Multi-Purpose Lithium EP (NLGI-LB) didn't stand up as well as the cheap Walmart SuperTech Lithium EP-2 Moly (NLGI-LB). The quaker state stuff washed off. Don't know if it's because of the Moly, but those were the results. Next time I grease i'm going to use the Marine MP grease so I don't need to reapply for sometime.
Photos soon when I complete the injector early this week.
fastcarny
Oct 6, 2015 10:42 AM
Justin Kroll
Sep 2, 2015 11:06 AM
