Best battery for an 07 w/ audio system
Old Apr 4, 2009 | 08:54 AM
1hawaii50's Avatar
I'll be installing my audio system w/in the next couple of weeks, and was wondering what would be the best dual post battery? I don't know if I can connect everything to the single post factory battery, so I figured I'd upgrade the battey too! I will be installing:
Morel Dotech Ovation 6 comps for front soundstage
Arc 6.5 co-ax for rear fill (in rear doors)
2 Hertz EBX200R 8" boxed subs in trunk.
1 Arc KS300.4 bridged to front comps (350 X 2)
1 Arc KS300.4 bridged for subs
1 Arc KS125.2Mini for rear fill
I'm going to run 1/0 power off of the battery (fused) to a distro block in the trunk.
I'm also going to run 1/0 ground off of the battery to a distro block in the trunk.
I should have enough 1/0 left over to do the "big 3".
I'm looking for a good dual post battery to power this system. I still have the stock alternator.
Old Apr 4, 2009 | 09:01 AM
Optima baby.
Old Apr 4, 2009 | 02:32 PM
1hawaii50's Avatar
Some people love Optima's, others hate them...guess it's a roll of the dice. Red top, or Yellow top? The yellow's are the deep cycle batteries, but I'm thinking the red top would be better for me as most of my driving distances are not that far...thus I don't think my alternator would be able to keep up a charge on a deep cycle battery. Or am I way off in my thinking?
Old Apr 4, 2009 | 04:16 PM
I VIK I's Avatar
How many watts RMS is all this stuff?
Im taking in about 500W RMS which is really nothing and I use a redtop, for more demanding systems go yellowtop and even more demanding systems go with a batcap or stinger. Personally id stick with optima.
Old Apr 4, 2009 | 04:59 PM
1hawaii50's Avatar
I'm looking at about 1600 watts rms between the three amps.
Old Apr 4, 2009 | 05:30 PM
BLACKonBLACK98's Avatar
Former Vendor
optima is the consumer answer. there's a lot of equal or better batteries for anywhere from less to considerably more. you need to be buying a battery by specs, not brand names. find out the ratings of your oem battery and determine the maximum size you can physically fit. a lot of the time those "high performance" batteries can't keep up with the oem specs, much less offer an improvment. cca, ca, ah, and rc are the specs to be noted. google can tell you what they are if you don't know. i bought 3 bs batteries for my q before i realized that there was nothing stronger than an oem replacment for my application.
brand is pretty much irrelevant since most batteries are made by a hand full of companies and rebadged anyway. get better than oem specs at the lowest cost possible.
Old Apr 4, 2009 | 07:33 PM
AscendantMax's Avatar
i have roughly the same power in my 06, and still using the stock battery. no dimming or voltage issues here.
Old Apr 4, 2009 | 08:32 PM
1hawaii50's Avatar
Thanks, that's good to know. I think I'll cut the factory battery terminals off of the OEM cables to the battery and get a couple KnuKonceptz battery terminals so I can get my 1/0 on the battery w/o any issues. That was one of the reasons why I was going to replace the battery. I figured if I could get a battery with top posts and side posts then it would make connecting things that much easier.
Old Apr 4, 2009 | 08:46 PM
i just clamped the ring terminal off my 0 gauge to the nut holding the stock cable in place. no need to cut anything. i'll snap a pic tomorrow.
Old Apr 5, 2009 | 05:41 AM
1hawaii50's Avatar
I'm going to be using my extra 1/0 to do the "Big 3" upgrade. I'm going to have 2 runs of 1/0, and 1 10g (fog light HID kit relay harness) running off of the positive side (1 run into trunk, 1 run to alternator). I'm also going to have 2 runs of 1/0 running off of the negative side (I'm going to run 1/0 off the negative into the trunk for the ground, and the second 1/0 from battery to chassis ground).
That's why I was thinking of a dual post battery, and/or using either of these:
http://www.knukonceptz.com/productDe...prodID=BT-104P
http://www.darvex.com/BTRP/XScorpion...+Terminal.html
Old Apr 6, 2009 | 01:47 PM
shyheim07's Avatar
I got a Kinetik 1800 under the hood. Love the battery..works great in the winter as well
Old Apr 9, 2009 | 02:16 PM
FlipCpt45's Avatar
i have a blue top
and i dim (at high volumes), because i only have a single 4GA ground to chassis.. also i think my ground for my 4 channel is loose / not making good contact as i put it ON TOP of my mono amp ring terminal
Old Apr 17, 2009 | 12:32 PM
nene503's Avatar
1hawaii50,
let me know and take pics of your big three especially how to connect the alternator to battery cable.
Old Apr 17, 2009 | 07:48 PM
1hawaii50's Avatar
I'll take pics of my complete install. I have to do an install in my buddy's 08 Suburban first, then I'll get to mine. I can't start his until the weather decides to cooperate first !
Old Apr 20, 2009 | 11:46 AM
M1RAG3's Avatar
Exide Orbital "Purple Haze"...hands down a very versatile battery.
Even with very cold winter temperatures here in Canada the battery works great...I am running 1200+ W RMS between 2 amps and I've had the battery for 4 years with no problems. Even before I got my cap. I had no dimming issues at very high loads. They are priced about the same as the Yellow top.
Old Apr 23, 2009 | 04:50 PM
thomatt12's Avatar
For serious audio applications, I say the best choice would be Optima Yellow Top battery. The Yellow Top is more for multimedia applications such as sound systems in a vehicle. Plus it has deeper cycle than Red Tops, thus improving performance for sound systems.
__________________
Aceomatic replacement parts
Old May 16, 2009 | 07:03 AM
maxprivate's Avatar
Black Lion
__________________
is the reserve power on these batteries the time we can run audio equipment without having the engine on and draining the battery?. I think the Red Top is rated for 120 min.. or is it 80 min? Am I right?
Old Jun 28, 2009 | 12:31 AM
ovilla's Avatar
Optima red top!!!
Old Jun 28, 2009 | 02:12 AM
2 GO B4's Avatar
yellow top...had systems in my last 4 cars and never had a problem with this battery!
Old Jun 29, 2009 | 05:56 AM
Batxel's Avatar
blah
Optima Red Top. I've had it for about 5 yrs now and it's never complained
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
